Old 12-14-2019, 09:58 PM   #1
Joyriding_86
Drives: 2015 Firestorm Frs
help reading logs oft, knock?
hello, i need help trying to to figure out if my car is slowly dying or if its bad gas? so here is a little bit about what happen awhile back i got some i guess low E% gas and it started to pull time (me guessing)went all the way low to E, filled up again but now i noticed the ADV Multi i is not 1 and the LTFT is really low. (see data linked) i dont know if i should just go back to 93? just run out the gas and refill E85? retune for 87-93 untill tank on on E cause of the LTFT? Drain the tank, look for other problems or is the engine in a downward state now, and its too late?
PS i have an 15 frs with around 67k miles if this help any
Thanks all for reading and helping in advance
https://datazap.me/u/retrojames/knoc...data=1-9-10-11
https://datazap.me/u/retrojames/knoc...og=1&data=1-12
@Steve_99
Joyriding_86 is offline   Reply With Quote
Old 12-15-2019, 05:29 AM   #2
steve99
http://www.ft86club.com/forums/showthread.php?p=1842501
Judging by the ltft arround -15% and knock and low iam id say you got some very low ethanol content e85 like 50%. Drive easy till you get some better e85.
Knock Knock? Expired Warranty Frivo Issues | Warranty | Recalls / TSB 20 08-17-2020 09:04 PM
Engine Knock Corr. reading through OFT ShadowReaper Engine, Exhaust, Transmission 0 11-24-2017 08:26 AM
installed supercharged keep getting knock. datazap wont load logs RacerX661 Software Tuning 1 09-17-2016 10:09 PM
Help with OFT Logs FirestormFlex Software Tuning 2 12-08-2015 08:35 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
