Drives: 2022 BRZ sport-tech
Oil coolers for DD/HDPE cars...
I recently picked up a 2017 BRZ as a daily/track day car to replace my 8th gen SI. My track use consists of 4-5 two hours track sessions a season. I have been reading up on this car quite a bit and it appears that an oil cooler is an ideal upgrade if the car sees track time. However, they are not without problems considering that I live in the North and our harsh winters can cause quite a bit of problems. Problems include oil never getting up to operational temp (-13F ambient is not uncommon), exposure to road salt rotting out the cooler and hardware, potential leaks etc. I also don’t want the oil cooler to create any warranty issues down the road as it still carries a 3 year powertrain warranty. On the contrary, I have also heard of members indicating as that as long as you use a quality synthetic and up the weight to 5W-30, an oil cooler is not an absolute requirement, especially with the relatively limited track use. I am sure there are members in the same situation as me and I wanted to gauge what others have done. In the past, I have never needed an oil cooler on the past cars but they were all Honda B and K series engines which are quite robust.
Thanks. |
Drives: 2013 WRB BRZ
There are a few companies that make oil coolers with thermostatic sandwich plates to help with cold starts. There is also the OEM WRX/Forester oil cooler kit that might be of interest to you. There is definitely the risk of the warranty issues if the dealer is picky. The OEM version would be much easier to hide since its really just a sandwich plate and a couple small coolant hoses.
Drives: 2014 FR-S
I'm using a mishimoto cooler with the thermostatic sandwich plate. It's not had any troubles to-date. We've seen <10*F a couple of times.
-Mike
#24 CS/CSR |
BoostedBRZ
Drives: Turbo BRZ
FYI, even with the thermostatic plates, oil will still bleed through and it will cool down. I live in Chicago, and during the winter months I just had to shove a piece of cardboard in between my bumper grille and the oil cooler itself and it helped to keep the temperature in check. When the warmer months came, I removed it.
You can block off the cooler core in the winter to keep air flow off of it, should help w/ reducing the effect of the cold weather on the core. The FXT style heat exchange may help in your case, but they often don't provide enough capacity for extended track use.
Did I read 2 hour session correctly? Like non stop? |
Most of the better "plates" have a thermostat built in. In the winter duck tape over the oil radiator will help. Your engine is then running as the stock setup, as the extra cooler is only an add on.
#7 | |
Drives: 2017 toyota 86
#8 | ||
Thank you for all the suggestions. I have thought about blocking off the oil cooler in the winter but that doesn't help with salt exposure (if it's even a problem), potential leakages and potential warranty issues.
Thanks. But I have read that this setup doesn't really help all that much once you get on the track and start driving the car harder. Quote:
JHerbert Racing
Drives: 2013 Scion FRS
I will always plug my favorite oil cooler setup when I see these threads. Check out Maximal Performance's thermostatic kit. They use high quality off the self components and happily replace individual components ,say if your cooler core rusts out, instead of making you buy a full kit again. They will cut custom size lines for you, the customer service is great and the kit isn't as expensive as the rest. I have had one of their kits on my heavily tracked FRS for 10k+ track miles and it has never been an issue.
#10 | |
Check out the Jackson Racing oil cooler, which I consider the bare minimum for a tracked car. Quality components with individual replacements available. GReddy makes a superior oil cooler, albeit at a higher price. Also quality components with individual replacements available. Thicker oil is often a bandaid, not a solution. |
#11 |
Drives: 2015 FRS
+1 on Jackson Racing. Plus, it fits perfectly with the OE and TRD intakes.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
#12 | |
Drives: '23 BRZ
Run 5w30 in the when doing track events. Switch back to 0w20 for winter months. |
#13 |
Drives: '23 BRZ
#14 | |
Site Moderator
Drives: Stuff
Not that I suggest it but I am far more OK running a b series VTEC motor that way than an FA20
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| WTB: FRS/BRZ for HDPE/track days | GrandSport | Want-To-Buy Requests | 2 | 10-30-2018 07:53 PM |
| PitBulls AX/HDPE 86 | pitbull008 | Member's Car Journals | 13 | 05-21-2018 11:00 AM |
| HDPE tire | klear | Tracking / Autocross / HPDE / Drifting | 40 | 02-08-2017 04:43 PM |
| How many quarts of engine oil for cars with oil coolers | toby714 | Engine, Exhaust, Transmission | 8 | 12-11-2014 07:16 PM |
| Helmets for AutoX/HDPE | drewbot | CANADA | 16 | 03-26-2014 08:40 PM |
