Old 12-07-2019, 04:36 PM   #1
George Rosebush
Drives: 2015 Scion FRS
Do we have tow points front and rear stock?
I'm looking at the requirements for a trackday at Chuckwalla, here,
Have a tow point (front & rear).
Tow hook or tow point you would feel comfortable with in case of an off-road excursion.
I know you can add a tow hook (How?), but do we have usable tow points front and/or rear?
Also, what helmet would you recommend? This is what's required:
Proper driving gear: HELMET Snell or DOT 2010 or newer. M or SA Required for track use.
George Rosebush is offline   Reply With Quote
Old 12-07-2019, 04:59 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
yes. 1 in front, and 2 in the rear. the tow hook is in the trunk next to the spare, and must be screwed in.
Old 12-07-2019, 05:19 PM   #3
HaXx
Drives: jrsc_brz
you are lucky you just use a moto helmet, most places require a car helmet, i have like 10 moto helmets but no car helmets. the towpoint in front is where most people mount the off center license plates
HaXx is offline   Reply With Quote
Old 12-07-2019, 05:20 PM   #4
George Rosebush
Well, if most places require an auto helmet I may as well get that, I was just wondering that too. They also do moto racing there, so maybe that's why that's even mentioned, they may require an auto helmet for a car.
Old 12-07-2019, 05:51 PM   #5
ls1ac
ls1ac's Avatar
summit racing, see Zamp, about $100. will get you a 2015 rated helmet. Not recommended for racing but great for track days. Get your own, rentals are the pits, also they usually charge 20-25 per event. Do four and your ahead.
The Following User Says Thank You to ls1ac For This Useful Post:
strat61caster (12-07-2019)
Old 12-07-2019, 06:48 PM   #6
strat61caster
strat61caster's Avatar
I like my cheap Zamp, just fine for HPDE, AutoX and the occasional indoor Karting session. Open face is more comfy, I pull the closed face off almost instantly but like I said, closed face is useful for the occasional kart session.
Look for the squares in the rear bumper and the circle in the front right side of the bumper, as mentioned tow hook in the trunk screws in as needed, putting it on before you hit the track may save you from having to slop around the mud to install it if you go off.
ineedyourdiddly
Old 12-07-2019, 08:06 PM   #7
George Rosebush
I just got a Snell M rated motorcycle helmet for $150 because to me it was worth it to be able to try it on at a local store. It's a Sedici Strada Primo.
I just tried it on in the car, I'm 6'4", so it works, but it's kinda hitting things. How do I deal with the fact that the back of the helmet now pushes my head forward on the headrest and also hits the part of the roof that curves down? (There's a pocket for your head if that makes sense)
Old 12-07-2019, 08:23 PM   #8
strat61caster
Pull the head rest out and flip it around and stick it in "backwards"
Some smart people made this car.
ineedyourdiddly
trvth (12-17-2019)
Old 12-07-2019, 08:26 PM   #9
George Rosebush
Holy crap, thanks, that's genius.
Old 12-07-2019, 09:01 PM   #10
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
This is unnecessary and will eliminate your head and neck support (especially in the case of a crash). You can sit comfortably with the headrest in the proper configuration.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Opie (12-09-2019)
Old 12-07-2019, 10:58 PM   #11
new2subaru
Weight Weenie
Drives: 15 FR-S
Trust me, you'll get used to it and it will become a non issue
FS: Stock front calipers & rotors, front/rear pads and lines Tristor Brakes, Suspension, Chassis 0 08-14-2018 02:09 PM
FS: Raybestos ST-43 front and rear pads. Front for Stoptech BBK, rear for stock rever5e Brakes, Suspension, Chassis 1 03-16-2015 12:02 PM
track pad front, stock rear? speedy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2014 10:33 AM
AP Front with Sti Rear or Stock Rear? Pacific Auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-07-2014 08:53 AM
Exact rear jackup points... illustrated Harvey Scion FR-S / Toyota 86 GT86 General Forum 14 05-17-2014 03:43 PM
