Old 12-06-2019, 05:49 PM   #1
RealShkillz
The White Pearl
RealShkillz's Avatar
Drives: '13 Whiteout FR-S M/T
2013 Scion FRS Radio Problem
Hey guys,
So this is a strange problem. My radio will light up to full brightness when the headlights are turned on, so all normal there. However now during the day it will also turn it's brightness up to full as if driving at night, which is annoying but not the end of the world. Another however, it will now turn off while braking... effectively not being back lit as it's supposed to be during the day. So the end result is you drive down the road during the day with the radio brightness at full and everytime you brake it dims, and out of the corner of your eye this things is just turning on and off.
Anyone heard of this before, or have any idea would could be the cause?
It's the stock upgraded pioneer unit the car came with.
RealShkillz is offline   Reply With Quote
Old 12-06-2019, 06:44 PM   #2
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
That is a strange one. I don't have the fancy upgraded HU, just the cheap ol basic one but never seen that happen. First I suggest you try adjusting the brightness via the dial to the left of the steering column, turn that down and it should not be at full brightness anymore. Next I would check the voltage on your battery, it could be as simple as the battery nearing the end of its life and not able to provide that much juice.
Then I would take a gander through all the settings on your HU, not familiar with that one but it may be related to a setting for auto brightness.
Now something I would test, with the car running turn on the map light and then apply the brake. If you see that dim along with your HU then you know something is up with the voltage.
Best place to start with something like this is make the best guess you can at what could be the cause, then think of a way to test and rule that idea out. Eventually you should either figure it out or get enough info to provide for someone else to get more ideas to test.
Good luck buddy, hope you get it figured out. Worst case scenario, you gotta buy a new headunit.
DandoX is offline   Reply With Quote
2013 Scion FR-S Automatic Shifter Problem Kazoku_ Scion FR-S / Toyota 86 GT86 General Forum 3 03-21-2023 02:59 PM
2013 Bespoke Radio vs Stock Radio Components MenoSkyz Electronics | Audio | NAV | Infotainment 1 12-26-2017 02:40 PM
FS: 2013 Scion FRS upgraded Pioneer Radio, door speakers, amp Takumi788 Audio/Visual, Electronics, Infotainment, NAV 8 08-23-2017 09:29 AM
Adding XM Satellite Radio to 2013 Scion FR-S 10 Series RJasonKlein Electronics | Audio | NAV | Infotainment 2 12-22-2014 12:11 PM
DVD in radio problem. Covo_86 Electronics | Audio | NAV | Infotainment 1 05-07-2014 10:33 AM
