Old 11-30-2019, 07:57 PM   #1
solidsnake11
Drives: brz
delicious tuning flex fuel
C
solidsnake11 is offline   Reply With Quote
Old 11-30-2019, 08:52 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
are you talking about the one that replaces the rear o2 sensor (the black plug)
Breadman is offline   Reply With Quote
Old 12-01-2019, 04:52 AM   #3
steve99
Originally Posted by solidsnake11 View Post
I bought a delicious tuning flex fuel kit at a scrap yard and the end that plug into the 02 sensor has only one grey wire. Could someone post a picture of that plug showing the wires.
Thanks
Ok that sounds like a 2017 + compatavle kit.
With the 2017+ cars you could not source the volts and earth from the rear 02 like you could on earlier cars. With the earlier cars signal volts and earth all sourced from rear 02 made very simple imstall
So the single wire going into the rear 02 socket is likely the sensor\signal wire back to the ecu.
What tune sysstem are you using to go flex ?? If its oft it doesnt support rear 02 conmect, you will need to reroute the sensor\signal wire to evap input on ecu
If ecutek it will accept either
And oft doesnt support 2017+ cars either
Hopefully thte kit has the volts and earth conmections that you will need to make
Old 12-01-2019, 12:33 PM   #4
Grady
Grady's Avatar
Thanks steve,
I think the wires got pulled out of the unit.
I have the kit with fuel pressure. It has 3 wires to the rear O2 sensor. Then an additional ground. If it has had a wire pulled out probably least of your worries as it looks like the corrosion has taken out a chip.
Edit: Mine has nothing installed on C7, but chips on R1 and L3 just to the right of TP10 where the power comes in.
Old 12-01-2019, 05:09 PM   #5
steve99
Thanks steve,
Attachment 183122
Hmm that circuit board looks like its got water damage, ie its been wet with power applied looking at that white corrosion, not sure how you will go with it
OFT with Delicious Tuning Flex Fuel Kit Jollibee86 Software Tuning 34 02-02-2022 07:51 PM
FS: Delicious tuning flex fuel black stainless steel braided fuel lines iceblaze Southern California 0 09-12-2019 03:36 PM
FS: Delicious Tuning Flex Fuel Kit BA9092 Engine, Exhaust, Bolt-Ons 0 08-13-2019 09:30 PM
WTB: Delicious tuning E85 flex fuel kit trackrat.e30 Want-To-Buy Requests 0 09-13-2018 04:22 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
