Old 11-29-2019, 10:16 AM   #1
casing
Drives: stock
supercharged cars in winter.
Hey all. Its starting to dip into the negatives here in canada.
Yesterday it was -10 C, and on cold start when the car does that load thing to warm up the cat, my car was making boost at idle. I doubt that's good when my oil temperature is at -10 C.
Should I look into a different tune for winter?
Edit: car is edelbrock supercharged.
casing is offline   Reply With Quote
Old 11-29-2019, 10:21 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
buy a civic type r for winter duties. it's the only reasonable answer.
Joveen (11-29-2019)
Old 11-29-2019, 10:22 AM   #3
StraightOuttaCanadaEh
Wes
I've also pondered this, wanting a supercharger in future
Instagram: @gt86ws
Old 11-29-2019, 10:24 AM   #4
casing
Drives: stock
Lol. Thanks I needed a good laugh.
Old 11-29-2019, 10:46 AM   #5
HaXx
Drives: jrsc_brz
i feel ya, the increased revs on start up on a fi engine, but theyre not THAT high. not up at like 2.5k rpm. theres no load on the engine though. i saw a picture of a $2,500,000 Koenigsegg regera rs driving in the snow, the caption was "think about this next time you want to take your shxtbox off the road for the winter" i was like dang that steering wheel costs more than my car.
cold start rpm wont cause your engine to fail, dont sweat it. sweat tracking without an oil cooler, or doing the valve spring recall.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
bcj (11-29-2019)
Old 11-29-2019, 11:29 AM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Do you have an oil cooler? You may want to consider something that will help warm the oil up quicker like the Forester XT regulator or the Jackson Racing. Otherwise, I'd say just drive it gently till everything is warmed up. Don't you Canadians have engine block warmers too? I believe Subaru offers one.
MS, CSCS, TSAC-F, CPT
Old 11-29-2019, 12:07 PM   #7
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Having grown up in Edmonton, a Lower Radiator Hose Heater works much better that the standard block heater if your going with that option. It circulates warm water throughout the engine and radiator not just one spot on the block. Plus it is a lot easier to install.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 11-29-2019, 12:09 PM   #8
Joveen
Joveen's Avatar
Drives: Bone stock
This!!
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 11-29-2019, 01:39 PM   #9
casing
Drives: stock
I spun a crank bearing on my original motor so Its still in the back of my head. I'll over worry till the cows come home.
The main reason I was worried was because it wasn't even really cold outside (-10c isn't bad) and my boost gauge shows 4 psi on first start up and my xhaust is popping and banging lol. it's the -30 days I'm worried about.
The Following User Says Thank You to casing For This Useful Post:
HaXx (11-29-2019)
Old 11-29-2019, 01:46 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
A Civic Type R would be a wild ride, wintery, greasy, slippery roads mixed with a FWD with 300+bhp wearing wide tyres with crazy low profiles... I think the Twin would be a better companion even if supercharged.
Old 11-29-2019, 02:31 PM   #11
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You can always bypass the cold start idle by moving the car in gear for a second. I do it in the morning if I plan to idle before leaving for work.
Old 11-29-2019, 02:34 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
You only 'idle' before leaving for work.. not favouring idling throughout the day??
Old 11-29-2019, 02:44 PM   #13
tomm.brz
Drives: brz 2017 hksv2
Modify the tune to reduce the cold start effect?
Old 11-29-2019, 03:00 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
But the thermostat is closed. The pump is only circulating fluid available via the bypass circuit. Block heater is the way to go.
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 2 07-03-2016 02:50 AM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 0 06-26-2016 11:57 AM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
How do these cars do in the winter? Prog New England 19 09-25-2013 02:28 PM
