| CANADA Canada |
Drives: Car
Remote Starter for Manual
I have a couple questions for people that have installed Remote Starter for their cars.
Care to share the cost and how your specific one works? Is there any reliability concerns to the rest of the vehicle or the actual starter itself? Thanks. |
There will be zero reliability differences with a remote starter vs going out to the car and starting it yourself.
Cost will be pretty high compared to older cars, I priced it out for my wife's car (2017 Corolla) and it was going to be about $800 taxes in. Modern cars with immobilizers and security systems really add to the cost. One thing to remember with a manual car, you HAVE to remember to leave it in neutral. The remote starter won't know if it's in gear or not and will try to start it even if you leave it in gear. Depending on how/where it's parked, it could roll the car into something or burn up the starter.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | 8inchAzN (11-26-2019), brandonblt2 (11-26-2019) |
#3 | |
ProCrastinationConsultant
Senior gif poster
Drives: 2013 Asphalt FRS
I dont get the appeal of remote starters? Maybe Im biased, a few years ago some asshole whos garage was just below our bedroom would remote start his stupid ass mustang at like 6am every weekday, it would vibrate our entire apartment and the dude would take so long to come out of his apartment (yes he would remote start it before even leaving his apartment) the car would auto shut off after 10 mins. Thse annoying mustangs would rumble and make so much damn noise early in the morning to what... warm the engine?! In northern California where the temp only gets to about 60F in the garage. Drives me crazy, save your money and walk out and start your car like humans have been doing for years. Also nearly all mustangs are getting to the point where they are as annoying as harleys.
Also FYI remote starting your car to warm up is not even the best idea for engine wear, unless your in a super cold climate where you need to heat the cabin there is no reason and your just causing additional wear on your engine at a time where your engine takes the majority of its wear. Start your car yourself, wait for the revs to start to fall then set off with a slight load on your engine, it will warm up faster and reduce wear for a longer engine life. |
| The Following User Says Thank You to DandoX For This Useful Post: | ElijahF (11-26-2019) |
#5 | |
I think you might be misreading the diagram? Usually a remote starter will bypass the clutch switch to allow it to start without having to push in the clutch.
| The Following User Says Thank You to wparsons For This Useful Post: | DarkPira7e (11-28-2019) |
#6 | |
You nailed it with the regional differences though. A guy in California saying that remote start is a waste of time is correct since they do not have to sit in a car at -20 for 10 minutes while the ice and frost clears up enough to see out the windshield. Try doing that and you will understand why people want it. It isn't a matter of warming the engine up so much as making the car even slightly drivable. I don't have it in my car and when it is really cold or iced up just go out and start it and go back in the house until it starts to melt enough that it isn't rock solid. The wife has it (on her car) and on the nasty days it is a slice of heaven to push a button from in the warm house and 10 minutes later go out to an easy to clear and at least tolerably warm car.
#7 | |
The higher quality (expensive ones) also include a sensor that will not let the car attempt to start if the shifter is not in neutral even with the clutch switch bypassed.
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (11-28-2019) |
Drives: 2020 Toyota 86 GT 6M
Would installing a remote starter affect warranty since it's technically a third party install
depends on what parts it screws with.
| Remote starter or cover for winter? | LWAA | BRZ First-Gen (2012+) — General Topics | 8 | 11-27-2015 10:49 AM |
| Remote starter on frs? | Brianbajnauth | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-09-2014 06:31 PM |
| remote starter - thoughts | jarviz | Engine, Exhaust, Transmission | 11 | 11-21-2012 07:27 PM |
| remote starter install | jarviz | NY / NJ / CT / PA | 3 | 11-21-2012 03:58 PM |
| cold weather & remote starter | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 11-10-2012 06:03 AM |
