Old 11-14-2019, 02:02 AM   #1
bobel
Drives: GT86
FA20 Reassembly - what sealants and where?
Just wondering what sealants people are using when rebuilding the FA20?
When I stripped my stock engine there was quiet a few strands of RTV caught in the pick-up mesh and it’s not really that surprising when you see how much RTV is used from the factory
Has anyone tried using some Anaerobic sealants as an alternative in some locations? I’m thinking of places like between the case halves and maybe the lower cradle/ sub-assembly where it’s clean tight fitting machined surfaces. I was planning to use Permatex 51031
As far as RTV goes what are people’s go to....and are you using the OEM bead recesses (e.g. inner lip of the front cover) or smearing across the entire flange faces?
bobel is offline   Reply With Quote
Old 11-14-2019, 02:41 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I suggest to do homework and consult manuals in depth regarding that. Recall botched cases of valve spring recall job on older twin with killed engine due sealant bits blocking off oil passages, so one should use right sealant, of right amount, at right places, not go by hunch/from experience on other engines and experiment with different replacements and different application.
Old 11-14-2019, 07:07 AM   #3
bobel
Drives: GT86
I think I’m general your right, but I guess my issue is that if I go by the Manual and stick with the OEM application than I’m highly likely to see RTV in the pickup again.
Also from my assessment of the engine during disassembly the OEM application look very heavy handed and unusual in some locations.
Old 11-14-2019, 08:58 AM   #4
bobel
Drives: GT86
Originally Posted by solidsnake11 View Post
Permatex 51813 / Loctite 518
Everywhere besides at the end of the head gasket where the gap is too large for it to work correctly.
Excellent that’s great info. From a look at the spec sheets I think the Permatex flange sealant i’ve gone with is pretty much the same just with a higher temp range so that should work.
Have you had any issues splitting the block or removing the front cover for example having used them?
Old 11-14-2019, 09:41 AM   #5
wparsons
wparsons's Avatar
I would stick with the manufacturer's suggestions, Subaru engines can be problematic if not sealed correctly.
flickr
Old 11-14-2019, 11:28 AM   #6
dholloway543
Software Hobbiest
Drives: 2015 FRS
Goto the toyota or subaru dealership. they have sealant that comes in a calking gun tube and is the best sealant ever. It would definitely be worth your money. Plus locktite
dholloway543 is offline   Reply With Quote
Old 11-14-2019, 11:55 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Wonder if Subaru mechanics use the recommended manufacturer's sealant when they do the valve recall.
I'd imagine the recall parts kit comes with it.
Old 11-14-2019, 01:53 PM   #8
dholloway543
Software Hobbiest
Drives: 2015 FRS
Just make sure you don't add too much and you will be good.
Old 11-14-2019, 02:18 PM   #9
wparsons
wparsons's Avatar
I'm sure they do, the issue I've heard is they aren't following the "map" of how much sealant and where.
flickr
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 08:40 AM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 07:17 AM
1 FA20 ROD!!! Klassickk1 Want-To-Buy Requests 1 03-05-2018 04:44 PM
Ode to FA20 tahdizzle BRZ First-Gen (2012+) — General Topics 7 01-14-2015 02:06 PM
FA20 DI in a BRZ/FRS blackhawkdown BRZ First-Gen (2012+) — General Topics 17 09-04-2014 03:46 PM
