Old 11-13-2019, 03:22 AM   #1
mi24hind
I shorted the door light, now she won't start
Oh boy,
I made the mistake of shorting the driver door courtesy light on my 2013 BRZ. Used a metal tool to pull the bulb with the battery connected. Oops. Now when I try to start the engine, it just goes into accessory mode without the engine turning over at all (freshly charged battery). I was also moving the steering wheel to access the flood lights. I thought it might be a steering lock issue, but perhaps I blew the BIU. Would that result in a 'no start'? Everything else seems to be working. I continuity checked all the fuses in the black box under the hood, and all the mini fuses next to the steering wheel.
Anyone else experience this? Going to be an expensive tow and fix at the dealer I think.
Sent from my SM-G975W using Tapatalk
mi24hind is offline   Reply With Quote
Old 11-13-2019, 12:17 PM   #2
norcalpb
norcalpb's Avatar
Disconnect the battery for like 20 min and try starting the car again.
I blew my door courtesy light the same way years ago and never had problems starting the car.
Old 11-13-2019, 12:18 PM   #3
mi24hind
Thanks, I actually had the battery disconnected all night and no luck starting it this morning
Old 11-13-2019, 12:34 PM   #4
norcalpb
norcalpb's Avatar
Maybe your battery coincidently took a crap overnight?
My car was starting fine last month until one morning it cranked like I had left the dome light on all night. Took it to a shop and it was barely holding 4 volts during a load test.
Old 11-13-2019, 12:35 PM   #5
mi24hind
Battery is fresh. Everything lights up and voltage is good. This is driving me nuts
Old 11-13-2019, 12:35 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Check all the fuses and relays first.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-13-2019, 12:44 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There is a 7.5 amp fuse labeled "STOP". It will blow when you short a light. It will disable your car. I had it happen. (Couldn't find info on this forum... Ended up on the Scion TC forum, found the info).
http://www.ft86club.com/forums/showthread.php?t=124270
I LIKE TIRES!
soundman98 (11-13-2019)
Old 11-13-2019, 12:47 PM   #8
mi24hind
I have continuity in all the mini fuses in the black fuse box under the hood and under the dash on the drivers side. Am I missing any fuse locations?
Old 11-13-2019, 02:37 PM   #9
mi24hind
Replaced the stop fuse, but she still won't turn over. I'm keeping the battery charged up btw
Old 11-13-2019, 04:34 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
So you can get power when on acc mode but do you hear the fuel pump whine when the ignition is turned on?
Or maybe clutch pedal switch?
Current DD: M235i
Old 11-14-2019, 01:45 PM   #11
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Check DOME fuse in the underhood fuse block
Old 11-15-2019, 04:01 AM   #12
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Any luck ?
mswbrz is offline   Reply With Quote
Old 11-17-2019, 02:25 PM   #13
mi24hind
Not yet. Going to tow to a mechanic in a few days. I'll update then! Thanks for the ideas guys
Old 11-27-2019, 10:49 AM   #14
dholloway543
Software Hobbiest
Drives: 2015 FRS
Auto or Manual, The manual has a clutch switch under the clutch petal that has to be depressed in order to start the car. Does this have electricity flow? It might be a short up that line making the car think you never pressed in the clutch.
dholloway543 is offline   Reply With Quote
Brz ts push to start & door arm rest shaynek Interior Parts (Incl. Lighting) 12 07-07-2019 01:29 AM
Underglow/footwell light controlled by door without using dome light or door switch pcguru2000 DIY (Do-It-Yourself) Guides 5 06-17-2018 12:09 PM
tail lights shorted out EN2_Squirrel Issues | Warranty | Recalls / TSB 7 01-19-2016 10:14 PM
This guy shorted my car battery Zhangy Scion FR-S / Toyota 86 GT86 General Forum 26 11-25-2015 02:46 AM
Questions on Remote Start and Door Hinges CFC BRZ BRZ First-Gen (2012+) — General Topics 9 09-14-2015 10:02 PM
