Old 11-01-2019, 05:59 PM   #1
504
504's Avatar
Drives: 2014 86 GTS
Boosted injector ratio
Hi folks,
coming up on my final ecutek tune revision hopefully. My tuner has the injector ratio raised on high loads upto 70% port as seen in the attachment. Question is, is this necessary for say 260kw on e85, 12psi? or 240kw 98.
How much can the DI take before running out of puff?? and I presume we want to maximise the use of DI for the purposes of knock reduction
my port injectors are deatchwerks 700cc
504 is offline   Reply With Quote
Old 11-01-2019, 06:54 PM   #2
tomm.brz
Drives: brz 2017 hksv2
Usually safe limit of DI is an opening time of just under 6ms, so that with colder weather it doesn't go over 6.5ms
But better stay at 6ms when cold
And more than 2ms from end of injection and spark
Modify accordingly to this
Old 11-01-2019, 07:48 PM   #3
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
I think your tuner has it backwards... 700cc injectors should be no where near that for your power level. With that PI/DI injection ratio your DI injectors would be around 2ms at redline.
Douglas W.
DBW is offline   Reply With Quote
Old 11-02-2019, 03:53 AM   #4
504
504's Avatar
Drives: 2014 86 GTS
I've got no way to measure ms unfortunately, this is really good information though
Would I be safe running 50% on high load? and what do you estimate ms to be?
thanks guys
Old 11-02-2019, 04:50 AM   #5
tomm.brz
Well, start at looking at the opening and increase DI to reach 5.5 ms maximum and you should be good
PI : DI Ratio Discussion Kodename47 Software Tuning 270 04-09-2023 07:27 PM
Overall Gear Ratio for boosted car Hags86 Engine, Exhaust, Transmission 16 12-11-2017 05:42 PM
Rear End Ratio White64Goat Engine, Exhaust, Transmission 6 07-07-2012 11:37 PM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
