JDM Vaping Stance Nation
Drives: 2013 White
WMI Nozzle location
Those who installed a WMI kit, where do you place your nozzle?
Pre TB or Post? I'm looking at the torque solutions TB spacer as it has a port for the nozzle. My only concern is some people who put the nozzle post TB says the WM can't atomize properly before entering the engine.
Clueless
| The Following 2 Users Say Thank You to YamahaR86 For This Useful Post: | Boris_Petrov (10-30-2019), Regular (10-30-2019) |
Drives: 2013 GT 86
In Europe, when we make LPG injection for better fuel economy, we normally mount the nozzles pst TB. But for meth injection and on a boxer engine I think it would be more appropriate pre TB.
Sent from my SM-A520F using Tapatalk |
Drives: 2017 toyota 86
What FI do you have?
Drives: 2013 White
Just a turbocharger. Had an offer for a snow performance stage 2 kit but think I might pass on it for now but still curious about where the nozzle will be mounted. The spacer from Torque Solutions says it is for Meth, Nitrous, or boost/vaccuum source. Otherwise I'd think for pre TB you'd drill and tap into the piping right before the coupler. Also reading up on people doing it pre-MAF sensor so in the event of failure (even with failsafes) the MAF can see the cooler charged air that was supposed to be there isn't there anymore and will adjust accordingly.
Clueless
Drives: RX-7 / BRZ
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
From my understanding, the further away from engine you inject the less cooling benefits from water but better methanol atomization. The closer the better cooling benefits but worse atomization. However most WMI use a 200psi pump with a finely atomized nozzle so it is spraying pretty well atomized from the nozzle. Plus with FI the more air speed/volume/pressure should help atomization as well.
It is recommended to spray post MAF as the WM can ruin the MAF sensor. But 6”+ pre TB as sometimes the WM can ruin the TB as well If injecting post TB its recommended to get a solenoid valve to prevent syphoning at idle. And about a dozen reasons I personally opted to trunk mount as apposed to using Ptuning’s kit. Also I'm using that TB spacer, but i am SC. If i was turboed i would probably place it 6-10” pre TB, or if i was making enough power inject both pre and post TB. |
| The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | Boris_Petrov (10-31-2019), YamahaR86 (11-01-2019) |
Drives: blue - Cosworth SC stage 3.0
Whenever I'd done water injection installations the injection point has been pre-turbo and the trick is to inject the water so its jet is targeted at the compressor nut to avoid eroding the impeller blades
the water mist at the compressor inlet then has a twofold benefit , 1) it helps seal the compressor and increase efficiency, 2) the temperature differential between the water and the hot compressed air is at the maximum so it all converts into vapour and reduces the air temp as much as possible Last edited by Matt@Cosworth; 10-31-2019 at 04:57 PM. |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | YamahaR86 (11-01-2019) |
| LOCATION OF BOV? | lilred | Forced Induction | 13 | 02-20-2019 04:38 PM |
| headlamp washer nozzle cover | Vladror | AFRICA | 20 | 12-29-2017 03:09 AM |
| Amp Location? | FNCrazy | Electronics | Audio | NAV | Infotainment | 10 | 07-09-2016 09:54 AM |
| FS: 550cc Long Nozzle Injectors | ex-gti | Engine, Exhaust, Bolt-Ons | 2 | 08-19-2013 01:31 AM |
| FS: 1300psi Pressure Washer and Gilmour Foam Gun(Nozzle) ($70) | kanundrum | Mid-Atlantic | 13 | 07-17-2013 10:10 AM |
