Old 10-24-2019, 08:34 PM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Window net
Anyone have any experience putting a window net on for scca compliance? Who's did you use?
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
The Following User Says Thank You to bmacfrs For This Useful Post:
Sisko's_Baseball (02-06-2021)
Old 10-24-2019, 09:23 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
@rice_classic might be able to answer that.
http://www.ft86club.com/forums/showthread.php?t=132443
The Following User Says Thank You to NoHaveMSG For This Useful Post:
bmacfrs (10-25-2019)
Old 10-27-2019, 12:07 AM   #3
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I used the Racequip window net mounting bar setup.
https://store.windingroad.com/racequ...pin-p1140.aspx
In my previous race car(s) I had the old seatbelt buckle style which worked fine as well but I like the spring loaded hinge of the racequip one better. It does have to be welded in and you'll need to figure out how you want to strap down the bottom portion of your net.
I also used the racequip net as well as I find the mesh type nets were harder for my peripheral vision to pick up what was immediately adjacent to me at speed.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
bmacfrs (10-27-2019), Sisko's_Baseball (02-06-2021)
Old 10-27-2019, 06:51 AM   #4
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
That's probably what I will use. I assume the upper pieces weld to the cage bar and the lower straps attach to the door bar.
Thanks for the info!
rice_classic (10-27-2019)
Window issue after window replacement Gabzor Issues | Warranty | Recalls / TSB 11 03-03-2017 05:48 AM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
