Old 10-23-2019, 03:52 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Crooked Steering Wheel
Anybody else had problems with their steering wheel going crooked? I've had several alignments done, but almost every time the wheel goes crooked to the left. I've asked the tech to make sure the wheel is absolutely straight during alignment, but it just keeps happening. Could there be something mechanical that's causing it or is the tech just screwing up?
smg1138 is offline   Reply With Quote
Old 10-23-2019, 03:54 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
Do you go to the same alignment shop every time?
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
strat61caster (10-23-2019)
Old 10-23-2019, 04:00 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If your steering wheel has ever been removed; it could be a spline or two off.
I LIKE TIRES!
i8ur911 (10-23-2019)
Old 10-23-2019, 04:58 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
"Goes" crooked or "IS" crooked.
As in is the wheel off right after alignment?
Or is it initially straight, THEN becomes off after a bit?
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
i8ur911 (10-23-2019), Leonardo (10-23-2019), NWFRS (10-23-2019)
Old 10-23-2019, 05:14 PM   #5
smg1138
smg1138's Avatar
It seems like it's straight right after alignment, but starts to go crooked after driving for just a little while. It always goes crooked to the left, not the right.
Old 10-23-2019, 07:31 PM   #6
x808drifter
LMGTFY
How long after?
By time you get to a stoplight?
A few days?
Old 10-23-2019, 07:35 PM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
Check your front tire pressures first
Old 10-23-2019, 07:41 PM   #8
Butterballz
Drives: Black FRS
I had the same issue. Mine was crooked slightly to the right after alignment. Got another alignment at a reputable shop and seemed good then got crooked again. Got another alignment at same reputable shop and asked to straighten out the wheel. Even compensated the steering rack to take into account if wheel was off a spline or so. Was straight right out of alignment then got slightly but less crooked than before.
Then I swapped the oem wheel with an aftermarket and it's now slightly crooked to the left. Might have aligned it a spline off tho but the splines seem big enough to create more extreme misalignment. Drives straight so no care.
Butterballz is offline   Reply With Quote
Old 10-23-2019, 08:54 PM   #9
wparsons
wparsons's Avatar
Have you checked to make sure there's no loose/worn parts in the front end? A worn balljoint or bushing could make the alignment drift after being set.
flickr
Old 10-23-2019, 11:16 PM   #10
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
That is most likely the cause. Has the car been in an accident?
davesrave is offline   Reply With Quote
Old 10-24-2019, 03:34 AM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Most likely alignment, toe quite likely the crooked crook... We have some bad roads where I live, the pot holes knock the alignment out. I've had alignment done 3 times in as many years.. The first 2 were planned as I had dropped the car and 3rd time due to steering wheel being slightly out...
Old 10-27-2019, 11:23 AM   #12
smg1138
smg1138's Avatar
So, this is kind of funny. The other day I put my Autocross wheels on and the steering wheel is almost exactly straight now. The RE-71R's I have on those rims are still almost new. When I took my daily's off, I noticed they've finally corded on the inside from camber wear. Could that have actually caused the wheel to go crooked?
Old 10-27-2019, 02:56 PM   #13
strat61caster
strat61caster's Avatar
Yes, tires wear in a weird pattern and create a pull
ineedyourdiddly
Old 10-27-2019, 04:29 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Only if the alignment is out, or uneven pressures, or the suspension is shot. Driving with tyres worn down to the cords isn't very clever.
Steering wheel crooked and ABS and Traction Lights On Brzxton Issues | Warranty | Recalls / TSB 12 03-22-2018 08:29 PM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
My steering wheel is stuck: Cusco steering wheel norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 4 01-01-2017 04:48 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
