Old 10-22-2019, 01:11 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Are Aluminum Lug Nuts Safe?
I'm casually shopping for some aftermarket lug nuts for my FRS.
Many of the choices are aluminum with others being steel.
Are aluminum lugnuts strong enough for a DD riding the GTA's frost destroyed roads?
I also wonder if aluminum nuts on steel studs might fuse together over time.
Constructive/educated thoughts most welcome.
Muskoka800 is offline   Reply With Quote
Old 10-22-2019, 01:21 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, Aluminum lug nuts are safe for DD. (insert the word quality in this sentence)
I tried a set of cheap aluminum lug nuts, used them for one set of tires, and threw them away. Went back to steel.
Aluminum on aluminum contact can cause galling. I wouldn't worry about it happening at all with the steel studs.
EDIT: After seeing the pic below of the lug nut fused to the stud; this is something to consider...
I LIKE TIRES!
Old 10-22-2019, 01:34 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
+1. Quality forged alu lugnuts should be safe, if one doesn't expect them to do unreasonable things. For example, if you do very frequent wheel mounts (such as changing wheels many times like in eg. prior/past track day), if you over-tighten them with power tools (frequent issue in many tire/wheel shops for time saving and due incompetence of some staff) instead of final tightening with hand tools, and don't expect of their shiny nice finish to last forever. It will get damaged. And if it's not some chinese cheap counterfeit lugnuts of known brands, that actually might be made of cheaper alloy of lesser strength.
So for DD car that sees usually at most two wheel changes a year for winter/summer tire change, where you remind tire shop workers to undo/tighten with hand tools, quality brand forged aluminum lugnuts are safe. For switch to/from track wheel set, for power tools use on lugnuts for personal convenience and speed, i'd go for steel lugnuts. Without abuse alu does fine, with abuse steel stands better against.
Old 10-22-2019, 01:35 PM   #4
Code Monkey
Drives: Subaru BRZ
I used 949Racing aluminum lug nuts on my Mazdaspeed6 racecar with great success. No luck on my BRZ, the lug nuts would fuse to the studs, picture. Did not use any antiseize on either car. Switched to steel lug nuts, zero problems so far.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Leonardo (10-22-2019)
Old 10-22-2019, 01:37 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Damn! That pic of your ARP studs is crazy! The lug nuts totally fused to the studs!
I LIKE TIRES!
Old 10-22-2019, 01:40 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My 1977 911S came with aluminum lug nuts from the factory. I hope they are ok.
Old 10-22-2019, 02:36 PM   #7
Muskoka800
Thanks for quick responses.
I'll add that no shop touches my car other than warranty work.
I use hand tools only to remove and install my wheels.
Not winter driven so seldom do I need to touch them and use the same set-up on-track (lapping only).
Anti-seize may be an option although I've read to never put anything (grease or anti-seize) on wheel studs. Dry installs only and torqued to spec.
Old 10-22-2019, 02:40 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Suggest to never use any grease or anti-seize on wheel stud threads. Just clean them, with eg. rug.
Old 10-22-2019, 02:40 PM   #9
GrabTheWheel
Drives: 16' BRZ
I'm using 949 lugs and ARP studs. Multiple wheel changes and no trouble yet. I will probably replace both the lugs and wheels after a few years though as they are both technically consumables.
GrabTheWheel is offline   Reply With Quote
FS: Counter Spcae Aluminum Lug Nuts (complete set) Lebby83 Wheels and Tires 4 04-20-2016 01:48 PM
Mishimoto Releases New Aluminum Locking Lug Nuts! Mishimoto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 03-21-2016 01:50 PM
New WORK RS-R forged aluminum lug nuts and valve stems - anodized red dminner Wheels and Tires 0 08-10-2014 12:41 PM
Aluminum Lug Nuts vs steel chromed OE? gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-21-2012 06:36 PM
