Drives: 2019 BRZ Limited 6 speed Red
Header without other exhaust mods?
Greetings everyone,
I just bought a 2019 Limited and am investigating doing some light bolt-on mods for the usual reasons (a bit more power and smooth out the 'torque dip'). I'm thinking of a header (ACE 350) and tune. From searching here, I'll probably keep the stock intake (maybe add a drop-in filter), and am debating the rest of the exhaust (I need to keep the cat for emissions compliance). Has anyone added a header but kept the stock exhaust? Most posts are about experiences with both a header and a cat-back (or axle-back), but most other posts also suggest that aftermarket exhausts primarily add noise (which I don't care about). Has anyone added just a header and a tune, but kept the rest of the OEM exhaust system? Are you happy with that? Thank you! |
Panda Trueno
Drives: No twin now.
The ACE gets rid of one of the cats just FYI.
There are a lot of people that just do the header / over pipe and retain the front pipe and catback. To me it sounds very "tinny" and not great, but it is quieter! |
Drives: 2013 frs red
Header/tune with otherwise stock exhaust. Sounds stock to me. Rather have a quiet car than a loud wannabe
Drives: JRSC BRZ SOLD
A lot of people have. You can keep the OEM main catalytic converter in the front pipe with just the header. It may of may not pass emission testing however.
Drives: manual Toyota 86
I ran my UEL header and over-pipe with the rest of the exhaust stock for about a year with a tune, I wanted to clean up the sound because a catless header on the stock exhaust does not sound great. The only reason people say it sounds stock is because its not to loud, but around town it can be a bit loud in the low ranges. So I cut that small resonator in the front pipe out and welded in a Vibrant Ultra Quiet resonator. It sounds better then stock and how the car should have sounded.
That Tinny sound is easily solved by cutting out the tiny front pipe resonator and replacing it with a quality resonator.
Panda Trueno
Drives: 2017 BRZ w/PP
i have a drop in filter, with ace headers and the rest stock. it sounds fine
Drives: 2017 BRZ PP , 2005 Saab 97X
Ive ran an uncatted UEL header with an otherwise stock exhaust system for a bit.
it gets slightly louder.. just a tiny bit. like.. miniscule. youll notice more engine noise and harmonics from your footwell. but thats about it. I had to run it after i went decatted as the combo header overpipe stock midpipe and catback i had was a bit obnoxious current set up is the catleass gruppe S header and overpipe to stock midpipe and out to the HKS Hi po single tip v2. the ace header is the best of the best, but you can get like JDL or gruppe s header for less than half the cost and youll get near the same performance. esp with the midpipe and axle back being OE.. the axle back on the stock cars is kinda wimpy.. |
#10 | |
From some quick searching and education, it looks like the FT86 Speed Factory catted header might be the one for me. Anyone using that one with the rest of the exhaust system stock? Thanks! |
#11 |
86 Challenge
Drives: 2017 BRZ
I run headers and a tune with an otherwise stock exhaust. Meh... The bump in power is noticeable, but only barely. The 2017+ cars got nicer headers so the difference is probably less noticeable than the earlier cars. Downside is there is much more tinny exhaust noise from under the car, and of course, emissions.
#12 | |
Drives: fdsgh
I am about to install Gruppe-s UEL and would love to do this and pair it with a catback! |
#13 | |
Drives: 2017 toyota 86
Also most of the catted headers use a high flow cat which helps a little, but most end up going bad in 2 years, and don't even guarantee you pass. The simplest thing would be to just do a drop in filter with ots tune, or go ace but swap back to stock come emission time. Its a pretty quick job once you've done it once or twice. Check your local emission laws sometimes you can pass with 1 failed ready check If you have no CEL, and might still pass with just FP cat. Or could try a 02 spacer if they don't do visual check. Any family or friends live in city/county that don’t require emissions? Could register car at their residence. |
#14 |
He asked if we were happy with just a Header on the stock exhaust system I gave him an explanation as to why I was not EG Header on a stock Exhaust exhaust sounds crap, I don't care what anyone says it does not sound "stock" Toyota and Subaru wouldn't let a vehicle leave the factory with it sounding like that, and you need to do some modifications if you want it to sound nice or OEM spec.
| SRT full header back exhaust + header? | KenTK808 | Engine, Exhaust, Transmission | 21 | 11-29-2017 05:07 PM |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| Exhaust mods on stock exhaust | FRSoxfan | Engine, Exhaust, Transmission | 9 | 01-12-2014 08:04 PM |
| What mods next? Exhaust? Intake? | Ludacrits | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2013 08:25 PM |
