Old 10-20-2019, 06:44 PM   #1
SmoothIsSlow
Very new 2018 BRZ, does this sound like a bad TOB?
Hi all,
I have a 2018 BRZ with 22k miles, was made in March of 2018, so I am not sure if it has the (supposedly not a hoax) revised TOB.
Anyway, just today, while driving around town, I realized that upon pressing and releasing the clutch pedal, there was a noticeable squeaking noise. No abnormal sounds when fully pressed in or fully released. I am pretty good about never leaving my car in gear at the light (I always go into neutral and engage the clutch).
Does this sound like a bad TOB? Or just parts of the clutch pedal pivoting assembly that needs some lubrication? Should I just schedule an appointment with a dealership?
SmoothIsSlow is offline   Reply With Quote
The Following User Says Thank You to SmoothIsSlow For This Useful Post:
humfrz (10-20-2019)
Old 10-20-2019, 06:53 PM   #2
humfrz
Originally Posted by SmoothIsSlow View Post
Hi all,
I don't "hear" anything.
However, you may wish to investigate the possibility that the clutch fork is dry and squeaking.
Quick & dirty: from @Ultramaroon
1. Detach the slave cylinder. Leave the hydraulics alone.
2. Remove the dust boot from the fork.
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger.
5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own.
6. Put a dab of grease in the top pivot where the slave pin goes.
7. Reassemble.
humfrz
Ultramaroon (10-20-2019)
2018 BRZ Sgaldi BRZ First-Gen (2012+) — General Topics 27 06-01-2019 06:13 PM
2018 BRZ STI raven1231 FR-S / BRZ vs.... 19 06-26-2017 12:39 PM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 11:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
