Old 10-18-2019, 01:45 AM   #1
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Need help identifying parts for stripped subframe
So attempted my front sway bar install tonight, all was smooth until I was reattaching the sway bar mounts (well, the subframe braces the sway bar attaches to) to the underside of the car (4 bolts on each side). Somehow, one of the holes in the subframe is stripped slightly - bolt appears to be fine but won't thread in. I didn't force it so I'm really surprised it got stripped... The bolt that is stripped is one of the shorter ones.
It is this bolt shown here (M000352, there are 2 in the front and one in the back, but only shows 1 in front in this picture for some reason).
In case this isn't clear, I'm following this rough install procedure. I'm at the 9:40 point in the video:
[ame]https://www.youtube.com/watch?v=j7P5FYtbfXA&t=702s[/ame]
(Thanks Justin)
I have never had this occur (have done 3-4 sway bar installs on my old WRX and a few other suspension installs). I need to pick up a tap and die kit (have never used one before). Can anyone point me to the correct thread pitch of that bolt so I know what tap size to buy? I tried to no avail to find a service manual but couldn't find it.
Any other tips?
BR-ZED is offline   Reply With Quote
Old 10-18-2019, 01:50 AM   #2
BR-ZED
BR-ZED's Avatar
https://parts.subaru.com/p/Subaru__/...901000352.html
I see this mentions M10x26.5. Is the 26.5 the threads per inch or length? At first I thought it was threads per inch but now I think it is length...
Old 10-18-2019, 02:28 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes it's length. Also it's on millimeters. But you already know that. Lol
The Following User Says Thank You to Mr.ac For This Useful Post:
BR-ZED (10-18-2019)
Old 10-19-2019, 12:29 AM   #4
BR-ZED
BR-ZED's Avatar
It is M10 1.25 in case anyone has this issue.
Home Depot has a little rig that you can test the bolt in. However it's easier to just measure with a ruler. 1.25 mm between threads indicates it is a M10 by 1.25
Got my die set I found it pretty easy to use... Got the threads all cleaned up and the car back together in time for the autocross this weekend .
The Following 3 Users Say Thank You to BR-ZED For This Useful Post:
norcalpb (10-19-2019), soundman98 (10-19-2019), strat61caster (10-19-2019)
Old 10-19-2019, 12:32 AM   #5
norcalpb
norcalpb's Avatar
M10X26.5mm long as well
Old 10-19-2019, 12:33 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i have a few of these in the tool box specifically for this situation. they've got all sorts of fancy one's, i just keep the 'standard' thread pitch versions. saves a lot of extra trips to the hardware store knowing what i need before i get there.
https://www.boltdepot.com/Thread_detective_-_Metal.aspx
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
BR-ZED (11-10-2019), EndlessAzure (10-19-2019)
Old 11-10-2019, 01:54 AM   #7
BR-ZED
BR-ZED's Avatar
That's a really good idea. Thanks! I'm always looking for ways to expand my tool selection. Or, maybe a good stocking stuffer, as family always asks what I want for Christmas...
Parts Shop Max subframe and differential risers philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 02-20-2024 11:05 AM
Stripped Studs ckmninja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-14-2019 01:22 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
Need help identifying a car! kALMIGHTY Off-Topic Lounge [WARNING: NO POLITICS] 15 09-28-2013 04:35 AM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 02:11 PM
