Old 10-12-2019, 05:55 PM   #1
bobel
Drives: GT86
Is it worth it to Port heads
Just wondering what have been people’s experience with Porting the heads on the FA20?
I know the heads flow pretty well as standard, and I’ve heard the castings are quiet thin and would not hold up to an aggressive Porting?
I see some have gone +1mm on exhaust valves but can porting help on the exhaust ports as I had not planned on changing the valves.
My goals is to rev to 8.5k with HKS supercharger on a fully built motor, with beehive springs but wondering if I should perform port aswell?
bobel is offline   Reply With Quote
Old 10-12-2019, 07:02 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
For revving it high you'll be hit by oiling system limitations imho. I doubt engine will last long with 8.5K redline.
Old 10-13-2019, 12:02 AM   #3
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
thats actually the exact correct answer
to even go further, the heads are already pretty extremely ported
what you need to do is flow match the heads to the exhaust and intake and change out the cams and valve springs so itll rev to that higher rpm, and most importantly check out the oiling system. its the biggest limitation
Ive read about cavitation at high rpms on stock engines. even an oil cooler cant help that
Clutch Dog is offline   Reply With Quote
Old 10-13-2019, 02:48 AM   #4
humfrz
Hello bobel -
As I recall, we have had this conversation before on this forum. You may wish to do a search and find that thread for some background information.
My recollection is that porting the heads on this engine isn't really worth the time and effort -
humfrz
Old 10-13-2019, 05:35 AM   #5
bobel
Drives: GT86
Thanks for the response folks
I agree on the oiling modifications, I will be installing racer x sump, killer b pickup, Reimax oil pump, and performing a host of modifications to the oil galleries (similar to the oil starvation thread) and if needed I’ll add an accumulator too.
Thanks I’ll have a search for the previous thread, was hoping for some experiences from anyone who has tried it too if your out there?
Cheers
Bobel
Old 10-13-2019, 06:06 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
I don't think that just listed oiling mods will suffice. At very least i'd think of dry sump / independent oil pump and alike things. And even then.. afaik element tuning tried to build 8.5-9K engine, but resulting engines lasted few races at most.
You already decided to went forced induction. Turn up a bit boost for decided power goals (or as SC, smaller pulley). Modifying engine for reliable much higher redline imho will be something ten times harder and more expensive. If you are set on high rev as main goal, i'd rather think of swap, eg. 11K rpm synergy V8.
Old 10-13-2019, 08:34 AM   #7
bobel
Drives: GT86
Ye it’s a valid point, and there are not many running the FA20 at high revs over a long period. My intention is to build to support higher revs but i’ll not be going there without first monitoring the oil pressures and seeing how the engine is holding as it’s tuned, if it can realistically only support 7.5k reliably then that’s where i’ll end up I guess, i’m not looking for huge power and to be honest i’m not sure how the HKS charger will hold up anyway as they have questionable reliability. Either ways it’s a little bit of experimentation and hopefully I learn something I can share with the community.
However would love a Synergy V8 swap but it’s just crazy money, I can build an FA20 myself for a fraction of the cost, as i’ve Priced up both as there is a Synergie V8 BRZ in a shop about 150miles from me and i’ve done the costings even with them selling me their current engine second hand.
Thanks again
Bobel
Old 10-13-2019, 09:57 PM   #8
solidsnake11
Drives: brz
I rev to 8000rpm daily. I did a clean up of the ports and smoothed the bowls. Was going to put in larger valves but didn't want to wait on the cutters to ship from india.
Motor has el cheapo eagle rods, je pistons, oil mods and extra large turbo.
Definatly get 14 plus heads with longer valves, revised rockers and different pivots or retrofit 13s.
Crawford reved to 9000rpm and tracked there car. Larger valves, valve springs, stock crank and i think stock block with oil mods.
solidsnake11 is offline   Reply With Quote
Old 10-14-2019, 04:03 AM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"Element Tuning has discovered that the majority of the gains from the Subaru head are attributed to the valve size itself and not the intake and exhaust ports."
http://elementtuning.com/competition...r-wrx-fa20dit/
Old 10-14-2019, 06:37 PM   #10
Grady
Grady's Avatar
Yes it is worth it to port the heads! are you going to get another 10HP.... NO! Some times that .2HP will win a race!
Old 10-14-2019, 08:43 PM   #11
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I had no idea what the Synergy V8 was until you sir. Thank you!
Drifter X is offline   Reply With Quote
Old 10-14-2019, 09:07 PM   #12
Lantanafrs2
Drives: 2013 frs red
Do it wrong and you can lose 10 horsepower
Old 10-14-2019, 09:40 PM   #13
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by Lantanafrs2 View Post
Do it wrong and you can lose all the horsepower
FTFY
Old 10-14-2019, 10:25 PM   #14
solidsnake11
Drives: brz
And all your coolant.
Used BRZ Heads pgranberg11 Engine, Exhaust, Bolt-Ons 3 12-31-2017 03:01 PM
FA20 Long Block and Port/Polish "Bare" Heads Allaskew Engine, Exhaust, Bolt-Ons 1 06-08-2014 12:48 AM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
