Old 10-07-2019, 03:30 PM   #1
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
Titan T-S5 wheels
So I’m seriously considering a set of these wheels in 18x9.5 with a plus 40 offset I believe (could be a 38 offset). Anyone have any feedback as to if they are good wheels etc and what’s a good price to pay for a set?
I see FT86 has me listed for around 1.8k USD.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 10-14-2019, 01:50 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Have you seen this thread?
http://www.ft86club.com/forums/showthread.php?t=118834
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
Jdmuscle (10-15-2019)
Old 10-15-2019, 02:14 PM   #3
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Titan wheels are good, not my ultimate favorite looks wise but definitely solid value for a forged wheel. Lots of dudes run them at the track. $1.8k USD is pretty inexpensive to get a good forged wheel anyways so that's a decent price IMO. (Evasive has them listed at ~2k) You might be able to negotiate with a smaller company to get a couple hundred off, but I doubt it honestly. I'd say just pull the trigger
Just FYI if you're still on stock suspension you'll almost for sure need to run coilovers on that size wheel, especially if it's +40 offset-- you'll likely be touching or extremely close to rubbing the perch depending on tire size. Only 245/35/18 or narrower will fit on stock suspension on 18x9.5 +38 (+40 has even less clearance), but that's already slightly stretched and if your tire runs slightly wide you still might rub. Ideally you'd want to run 255/35/18 or 265/35/18 on a 9.5 wide wheel but neither of those tire sizes fit on stock suspension.
Shizuka is offline   Reply With Quote
The Following User Says Thank You to Shizuka For This Useful Post:
Old 10-15-2019, 02:52 PM   #4
Jdmuscle
Thanks gents.. appreciate the feedback. I did pull the trigger and got the wheels. I’m going to install Tein Flex Z coilovers this weekend and then mount the wheels. I went with 255/35/18s for tires.
The Following 2 Users Say Thank You to Jdmuscle For This Useful Post:
Leonardo (10-15-2019), Shizuka (10-15-2019)
Old 10-23-2019, 01:56 PM   #5
Jdmuscle
Here she is with all of the above mentioned parts on her... absolutely loved working on the car over last weekend.
The Following 3 Users Say Thank You to Jdmuscle For This Useful Post:
HKz (10-23-2019), i8ur911 (10-29-2019), Leonardo (10-23-2019)
Old 10-23-2019, 02:47 PM   #6
WC-BRZ
Drives: Black BRZ
God damn, dude! You gotta post more pics - this looks killer
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Jdmuscle (10-23-2019)
Old 10-23-2019, 03:24 PM   #7
Jdmuscle
Here are some more pics... I’ll take more this weekend when I get her aligned.
The Following 4 Users Say Thank You to Jdmuscle For This Useful Post:
dhuang (10-28-2019), jflogerzi (10-23-2019), WC-BRZ (10-23-2019), weederr33 (10-23-2019)
Old 10-23-2019, 03:34 PM   #8
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
The car’s coming together really well. Looks incredible. Good job
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Old 10-23-2019, 06:07 PM   #9
WC-BRZ
Drives: Black BRZ
Here are some more pics... I’ll take more this weekend when I...
What are you lowered on and how much is the drop? And are those 245/40's or 255/35's?
Any rubbing at full lock?
One last question! How do you feel about the added weight? Even though these are light for their size, overall, with the larger tires, it's probably heavier, correct?
Old 10-23-2019, 06:09 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any particular reason to continue using this thread rather than an older http://www.ft86club.com/forums/showthread.php?t=118834 ?
Old 10-23-2019, 09:02 PM   #11
Jdmuscle
They are 255/35.. It’s actually not lowered at all. It’s in the stock height setting. I haven’t driven it a lot yet. I’ll get it aligned this weekend and I’ll report back.
Lifting the wheels and tires when mounting them I feel like net the new wheel/tire combo is still lighter given the increased tire size.
Old 10-26-2019, 01:18 PM   #12
Jdmuscle
@WC-BRZ
So got it aligned and drove it. Here are my thoughts
1) drives almost stock in terms of compliance goes compared to the Sachs dampers.
2) annoying squeak from the front driver side. I’m going to take it all apart and install it again to see what’s causing it
3) when going up driveways.. the rear bumper rubs where the blk tabs are. Dremel / stiffening the rear damper should take care of that hopefully
4) no rubbing at full clock
The Following User Says Thank You to Jdmuscle For This Useful Post:
WC-BRZ (10-28-2019)
Old 10-28-2019, 11:52 AM   #13
Jdmuscle
Update...
1) dremel worked perfectly in getting rid of the rubbing issue in the back.
2) WD40 got rid of the squeak in the front driver side
Driving this car now with these problems sorted out is simply what I was looking for since the day I decided to do all of these mods.
I can sincerely say.. I do not want to get out of the driver seat anymore. I just want to sit in it and keep in driving forever. Absolutely love the car!!
Will BRZ (10-28-2019)
Titan 7 Forged Wheels Evasive Motorsports Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 68 10-07-2022 11:58 PM
17x9 Wheels and Tires (2 sets) - Enkei RPF1 and Rota Titan jonesy Wheels and Tires 9 09-21-2017 10:01 AM
New wheels - Rota Titan 17x9 justinco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-18-2017 01:30 PM
WTB: M7 T-Titan AREN Canada Classifieds 0 07-29-2015 11:27 PM
R1 Titan Amuse ginstreet Engine, Exhaust, Transmission 39 04-28-2015 08:44 AM
