Old 09-29-2019, 01:56 AM   #1
juniorrr
Drives: Scion Frs
Help with Tomei Overpipe!
Hey guys so I’m about to install my Tomei overpipe but I wanted to ask you guys how did you torque down the studs onto the overpipe? Do I install it on the header first and then torque down the studs? Or do I try and torque the studs down first then install them on the header? It says use double nut at 29.4NM which is about 20ft lbs but when I torque it down the torque wrench caps at that spec and I’m afraid of going further in case of breaking the studs.. Please help thnx!
juniorrr is offline   Reply With Quote
Old 09-29-2019, 03:46 AM   #2
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
mswbrz is offline   Reply With Quote
Old 09-29-2019, 05:23 AM   #3
juniorrr
Drives: Scion Frs
Originally Posted by mswbrz View Post
Yeah i’ve Seen it not a good video and doesn’t answer my question unfortunately
Old 09-30-2019, 11:05 PM   #4
H1C
Drives: 2014 FR-S MT
I followed the instructions and torqued the stud onto the Tomei OP using the double nut method. If I had to do it again I'd back it off to 15 lb-ft or even less. At 20 lb-ft, the threads on one of the studs got stretched a bit, and I'll have to replace that stud at some point.
I think even if you hand snug the stud onto the OP, it'll get tightened down as you torque that end of the OP to the FP.
H1C is offline   Reply With Quote
TOMEI UEL Header and Overpipe FT86Logic Engine, Exhaust, Bolt-Ons 0 01-17-2019 10:34 AM
Tomei overpipe Jwkre8 Engine, Exhaust, Bolt-Ons 4 11-30-2017 01:53 AM
FRS – Tomei UEL, Tomei Overpipe, Stock Front Pipe, Manzo V2 exhaust Timmy_Jones Engine, Exhaust, Transmission 0 05-01-2017 10:29 AM
Tomei Overpipe awang0528 Want-To-Buy Requests 0 06-12-2016 12:37 PM
