| Engine Swaps Discussion of engine swaps. |
Xander Performance 2013 frs lsx swap
Hey guys. I have had this car for quite awhile and have gone through a few phases with the car. I bought the car and kept it relatively stock, engine wise as I already planned to ls swap it from the get go. Here is how the car looked after I installed air ride and wheels
![]() ![]() ![]() ![]() ![]() ![]() I then decided to be the first one to swap the new 86 bumper on the 13' frs. Too bad I waited this long to post it. I used all oem parts and made appropriate harnesses for fogs and also made head lights 100% plug and play including the led bar utilizing factory plug. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I then was hit with the black plague with spinning a rod bearing at 62k. ![]() ![]() ![]() ![]() ![]() ![]() So then you may ask, well now what do you do? Well for me, I think business like and I rebuild the engine so that I can sell it as a fresh running engine to add funds to the build. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Little bit of quality control here, but I got it fixed with a new set ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Ready to go to a new home. ![]() Here are some of the LS parts coming in. -Built F-Body T56 -LS6 engine block and 243 Cylinder heads -Wiseco pistons -Scat rods -ARP main studs -ARP Head studs -BTR Stage IV Cam -Mantic twin disk clutch -LS2 Throttle body -LS2 intake for now -Sikky Mounting solution -Hooker Blackheart LS2 Exhaust manifolds ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Alright lets see some pictures of the engine and trans installed in the car. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [IMG]https://scontent-iad3-1.xx.fbcdn.net/v/t1.0-9/71757703_1791723694304500_5246844190389698560_o.jp g?_nc_cat=101&ccb=3&_nc_sid=0debeb&_nc_ohc=iqb7crG zUesAX9P6Cyy&_nc_ht=scontent-iad3-1.xx&oh=61d96c66850892f3d068***e9d825f95&oe=605866 16[/IMG]![]() ![]() ![]() ![]() SIKKY steel driveshaft ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also went with a different Tilton clutch master to give me a little more room. ![]() ![]() ![]() Wasn't a big fan of how the Stock intake manifold fit so I opted for a new one that fits perfect. ![]() ![]() ![]() Also wasn't a fan of how the harness looked in the engine bay so I pulled the entire harness and ran it inside the cabin. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Prepping for my Emtron KV8 install ![]() ![]() ![]() Also got me a shifter that fits the car![]() ![]() Mocking up some AC components. ![]() ![]() I also moved the right front brake line that was on the firewall to in front of the engine to clean things up. Also have enough room for the hood latch bracket ![]() ![]() ![]() ![]() ![]() ![]() Started working on a production level Radiator kit that we will be bringing to the market soon for you all. ![]() ![]() As far as fueling goes for this. I will be making a lot of power in the end, so I went with the triple pump surge tank, ptfe lines, flex fuel, and all in a nice neat package. ![]() ![]() ![]() 1/2 aluminum sheet for mounting. ![]() ![]() ![]()
| The Following 6 Users Say Thank You to all4spl For This Useful Post: | Corley (10-25-2019), DustinS (10-04-2019), GrabTheWheel (09-28-2019), gtpvette (09-29-2019), Irace86.2.0 (02-09-2022), Wally86 (01-12-2022) |
Drives: LS Swapped Scion FRS = 440HP
'bout time this thread gets started.
| The Following User Says Thank You to spitsnaugle For This Useful Post: | all4spl (09-26-2019) |
2 ugga dugga's
Drives: Nike
You can use IMGUR on your phone. There's an app and you can upload photos easily.
| The Following User Says Thank You to Clash0901 For This Useful Post: | all4spl (09-27-2019) |
Alright guys, I posted a few more pictures working my way up to where I am currently with the LS swap. More of the more recent pictures to come shortly!!
More LS pictures posted. Let me know your thoughts.
Drives: "Baby Gurl" of FBM
Looks like a good time. Solid work!
Full Blown Motorsports
2JZ/CD009 drag car with license plates IG: Stevemode62 |
| The Following User Says Thank You to Stevemode For This Useful Post: | all4spl (09-30-2019) |
Drives: 2015 frs
Nice looks like your using the sikky swap kit. I have been wanting to see a swap with this kit. Interested to see engine, and transmission location compared to the other kits out. It looks like a good product produced by a good company with advanced tools to get it just about perfect.
Got some more pictures posted. Ran into some issues with trans tunnel issues. Had to shave some tabs off of the trans. Shifter spot seems pretty good. I'm going to see if I can get an MGW shifter located at the 6 oclock position. I also have another solution for the hydraulic side of things. More pictures to come!
| The Following User Says Thank You to all4spl For This Useful Post: | Zer0 (10-03-2019) |
#10 |
2 ugga dugga's
Drives: Nike
So far this thread is awesome! Curious, are you keeping the Airlift setup on it?
#11 |
Drives: 2013 Ultramarine FR-S
Is it me, or is that driveshaft not long enough? Looks short
#14 | |
| Questions regarding e85 swap on 17 BRZ performance package | TheCoryKight | Engine, Exhaust, Transmission | 1 | 05-08-2017 02:27 AM |
| Looking for Swap or trade 2013 86 gts manual to auto | Xylon | Australia Classifieds | 0 | 12-16-2015 11:12 AM |
| Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
| FR-S/BRZ Named Finalist for 2013 World Car of Year and 2013 Best Performance Car | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-08-2013 03:34 PM |
