Old 09-21-2019, 12:00 PM   #1
Dylon
Drives: Scion FR-S
Rear passenger coil over squeaking.
Hello,
On my 2013 Sicon FRS I have a set of JRZ RRS TWO - Double Adjustable Twin Tube Damper coil overs. Recently, one of the coil over on the rear passenger side only, has started to squeak. It only does this on even road at lower end speeds with very small bumps. If you push that side of the car down with your hands fast enough, it will start to squeak(this doesn't happen on any other side).
I've made sure every bolt is tight and they all have blue thread locker, the sway bar end links are in good shape (white line), and everything else down there looks good in my eyes.
Any suggestions? These coil overs were also rebuilt less than a year ago.
Dylon is offline   Reply With Quote
Old 09-21-2019, 12:46 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's probably the lower spherical joint squeaking.
As for what you can do about it... there's nothing much you CAN do. When a ball joint has started to squeak it's already too late. Ideally they would have been made with a grease fitting but as it stands, seems like they're built to die.
Maybe spray a bit of oil on it in the hope it can wick into it but I wouldn't get my hopes up.
Old 09-21-2019, 12:57 PM   #3
Dylon
Drives: Scion FR-S
Is the lower spherical joint, the correct term for lower ball joint? Never heard of it of it as that, just making sure. This would be replaceable correct? This is my first time having coil overs and I didn’t install them, don’t quite know if these are removed and built into the coil overs.
Thanks, Dylon
Old 09-21-2019, 01:29 PM   #4
RZNT4R
sphere = ball From the JRZ website itself
Uses spherical bearings
googling around it's hard to discern what pictures are from the actual FR-S parts, and it's doubly hard to find a picture that would show if the joint can be serviced without replacing the whole shock. Your best bet is probably contacting JRZ themselves.
Old 09-21-2019, 05:55 PM   #5
humfrz
That just may do it -
Back in the day, when we had a suspension squeak, we would mix up a batch of coal oil and 30 weight oil (50-50 mixture) and put it in a squirt can. Then crawl under the car and squirt things till the squeak stopped.
(Bubba approves this method)
humfrz
chaoskaze (09-21-2019)
WTB: 20 OEM lug nuts OEM Rear Shock mount+coil isolator skylinekin Want-To-Buy Requests 2 07-24-2018 04:59 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
WTB rear passenger tail light trdric Canada Classifieds 2 08-11-2015 02:15 AM
Dominant Engineering Custom Bc Coil Camber plates and rear Uca/Upper Control Arms thatcosta Canada Classifieds 2 04-23-2015 12:49 PM
Buzzing from rear passenger wheel Mattybro410 Issues | Warranty | Recalls / TSB 1 11-04-2014 10:25 AM
