Old 09-20-2019, 09:16 AM   #1
prandelia
Drives: 2015 FRS
Which intake fits? - Jackson Racing NA oil cooler
Was in a huge rush to build the car and didn't have time for trial and error so just used stock intake for now, but I want to use some sort of air intake to make more power, but it has to clear the Jackson Racing NA oil cooler.
Need the collective wisdom out there to help, but it also needs to be legit and make real dyno power. My car, with only silicone elbow, drop-in K&N filter, and full ACE 350 4-2-1 header/exhaust setup on E85 made 198whp (STD smoothing 5) and 195whp (SAE smoothing 5) using a Dynojet, depending on which one you use. This was at a premiere tuner, so it's legit power, they tune all our race cars. I would love to have another 5whp or so.
So if there is an intake out there that fits, and makes power, I'm all ears!!
Thanks again all!!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
The Following User Says Thank You to prandelia For This Useful Post:
86_IT (09-20-2019)
Old 09-20-2019, 11:43 AM   #2
86_IT
86_IT's Avatar
Revolution or Autofactory carbon induction box is the only intake proven to make power.
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
The Following User Says Thank You to 86_IT For This Useful Post:
new2subaru (09-20-2019)
Old 09-22-2019, 11:28 AM   #3
prandelia
Drives: 2015 FRS
Has anybody ever tried/dyno'd one of these Garage Vary ducts with the factory air-box for some true ram-air effect? I would imagine it would definitely reduce IAT's and help make more power, especially at speed.
It seem to be pretty well documented that these motors are sensitive to inlet air temps, so the cooler the better.
https://www.86worx.com/garage-vary-intake-duct.html
'15 FRS - GLTC spec
86_IT (09-22-2019)
Old 09-22-2019, 11:35 AM   #4
86_IT
86_IT's Avatar
Negligable gains.
Old 09-22-2019, 11:41 AM   #5
prandelia
Drives: 2015 FRS
Originally Posted by 86_IT View Post
Negligable gains.
'15 FRS - GLTC spec
86_IT (09-22-2019)
Old 09-26-2019, 05:30 PM   #6
prandelia
Drives: 2015 FRS
Tempted to try the TRD box, as I know it will fit with an oil cooler setup, and should out-flow a stock intake w/K&N, as the filter is larger. I really like how the stock type boxes keep IAT's low, mine runs about 90 deg in similar ambient heat, which is really good.
The ACE setup really gets the exhaust gases moving, so I feel like the intake is where my biggest choke point is at the moment. I know stock w/drop-in is decent, but I'm after every last hp, so it's already proven from intake shootouts that others make more power up top. DSsport had one where the KN Typhoon beat everything, but again, don't think it will fit w/ oil cooler unless you cut out the back of the intake box. It doesn't have a top, so I guess it wouldn't really matter......
'15 FRS - GLTC spec
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
BNIB JACKSON RACING OIL COOLER, FUJITSUBO EXHAUST, CARBING INTAKE RARE Pekingduck Engine, Exhaust, Bolt-Ons 16 04-24-2017 09:35 PM
WTB: Jackson Racing Oil Cooler wrb.brz Want-To-Buy Requests 0 03-12-2017 01:31 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
