Old 09-12-2019, 11:57 PM   #1
qqzj
Drives: MDX, Camry
Will 2018 Subaru Imprezza 16 inch wheels fit normal 86 (no big brakes)?
Looking at some wheels and a local seller is selling a set of Imprezza wheels. Spec is 16x6.5 ET 55. Tire is 205 55 R16. I did a comparison here.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
It seems that the biggest concern is that wheel will be 7mm closer to hub and there might not be enough room for brake caliper. A minor issue is that scrub radius will be -8mm. Is this going to affect the car's handling much?
If I add a 7mm (or 10mm spacer), will there be enough lug bolts left for the lug nuts to work properly? Any 10mm spacers to recommend? Appologize for so many questions. Thanks in advance!
qqzj is offline   Reply With Quote
Old 09-13-2019, 12:47 AM   #2
qqzj
Drives: MDX, Camry
I did some search and find this thread
http://www.ft86club.com/forums/showthread.php?t=22918
Here it is said that 16x6.5 ET53 can be bolted on directly. Not sure whether the addition 2mm offset going to change anything. The wheels I am looking at are just like these:
https://www.detroitwheelandtire.com/...845-sss-a.html
5x100, offset 55, 16x6.5, center bore 56.1
Old 09-13-2019, 12:58 AM   #3
qqzj
Drives: MDX, Camry
Well, I dug harder and came across this thread
http://www.ft86club.com/forums/showthread.php?t=56662
It seems they should work. But does the fitment is decided ONLY by 16x6.5 ET55? Is there any possibility that this specific wheel won't fit? Also I don't like the fact that the wheel will move inside by 7mm each side. Is it a good idea to add 3mm spacers to bring them out a bit?
Old 09-14-2019, 03:17 AM   #4
Yoniyama
Drives: BRZ 2018
Toybaru comes with 16-inch (16x6.5) wheels and 205/55-16 tyres as standard in many countries. The Impreza wheels should fit unless big brakes are installed.
Yoniyama is offline   Reply With Quote
Old 09-14-2019, 07:14 AM   #5
qqzj
Drives: MDX, Camry
The factory wheels in Australia for GT86 has offset 48
Sent from my Pixel 3 XL using Tapatalk
Anybody got 16 inch wheels on their FR-S /BRZ? Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 734 04-27-2022 06:11 PM
Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! JonMotoring Wheels and Tires 14 11-16-2015 06:24 PM
will an Imprezza oil cap fit the BRZ? Suparu Engine, Exhaust, Transmission 1 07-06-2015 06:59 PM
16 inch wheels on this car..? Walla Walla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 04-11-2014 01:05 PM
