Drives: '14
Feel a little 'bump' when I brake when CEL is on.
P0171 lean code. I've had it for a while now. I've noticed that when the light is on, and I brake, I feel a subtle 'bump' right before I come to a stop. When I clear the code, the car brakes 100% smoothly. How could a light cause my car to have that bump when I brake?
Drives: 2013 Scion FR-S Raven 6MT
Auto or manual?
Sent from my moto g(6) using Tapatalk
Stay squatchy, my friends
Drives: '14
Drives: car
Hm. I kinda experienced this with a different CEL (ABS sensor broken) causing limp mode, every time I came to a stop the car would almost stall.
Drives: '14
Well shit. I have an ABS code too (C1201). I didn't think too much of it. The slip lights only come on sometimes. Even when the light isn't on, I still feel the bump. So weird. My RPM's drop when I come to a stop and would sometimes almost stall as well but I'm assuming that's because of the lean issue from my P0171 code.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Sounds like
http://www.ft86club.com/forums/showthread.php?t=134579 But as always, if you've got fault codes, have those issues fixed FIRST. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | kev0 (09-12-2019) |
Drives: car
@kev0 limp mode was a pretty severe occurrence in my case. I was unable to rev past 3500 rpm, scary on the highway.
Take care of the ABS problem first and clear codes and see if your lean code goes away. |
| The Following User Says Thank You to radroach For This Useful Post: | kev0 (09-12-2019) |
No.
C1201 is there to inform you that there is an engine management problem. Repair the engine control system malfunction and it will go away by itself. |
| Brake firmness/pedal feel | Hyper4mance2k | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 40 | 05-22-2019 01:22 PM |
| New Ferodo Brake Pads Feel Sticky | kodyo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 04-30-2018 04:22 PM |
| Brake feel | bg15 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 07-27-2017 02:18 PM |
| Brake Feel Enhancement | Capt Spaulding | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-06-2016 12:33 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 01:29 PM |
