Old 09-03-2019, 10:50 AM   #1
coolguy1o1
coolguy1o1's Avatar
Drives: 2017 Toyota 86
Need some help on some wheels
First time buying wheels so I’m kinda lost. I found some enkei rs7 17x7 et42. The bolt pattern is 5x100 but the bore is 72.6 so I need some hub centric rings right? Also the guy said the stock lug nuts won’t fit so I need some skinner ones. Do they make those?
coolguy1o1 is offline   Reply With Quote
Old 09-03-2019, 11:45 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You don't NEED hubcentric rings. The lug nuts center the wheels with their conical base. I cant speak to the use of OEM nuts, but unless the 19mm socket doesn't fit in the bore, then I'm not sure why you'd need different nuts.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Feistyfrog (09-03-2019)
Old 09-03-2019, 12:20 PM   #3
Glitchy86
Drives: Red 86
From what I have red you need an aftermarket lugnuts. As for the hubcentric ring I would get them just to be safe they only cost 10$.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 09-03-2019, 12:20 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Why 17x7? Why not 17x8? Or 17x9?
I would also suggest a lower offset. Like +30 or +35 This will make your wheels flush and give you room for: 225/45/17 or 235/40/17 or 245/40/17 tires.
Hubcentric rings are inexpensive. IMO, they are worth getting. Our hub bore is 56.1mm
OEM conical lug nuts work on most aftermarket wheels. They are not spherical OEM nuts like honda's have.
I LIKE TIRES!
Old 09-03-2019, 12:33 PM   #5
coolguy1o1
coolguy1o1's Avatar
I’m fine with a 17x7, I don’t like that super wide look in the back and I like how it rides now. Plus I don’t need to buy new tires. The guy had a brz and test fit them on but said the oem nuts wouldn’t let him tighten all the way.
Old 09-03-2019, 12:51 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just looked, and the RS7 is a dual bolt pattern wheel. IMO they won't look as good as single bolt pattern wheels.
I imagine you are getting a killer deal on them used though.
Anyway, I would suggest getting some gorilla tuner style lug nuts; They are inexpensive, will work fine, and come in an array of cool colors. They are steel; great for many on/off cycles. Get ones with this spec. 12x1.25
I LIKE TIRES!
JesseG (09-04-2019)
Old 09-03-2019, 12:59 PM   #7
coolguy1o1
coolguy1o1's Avatar
I can get some covers that will hide the bolt holes. The guy will let them go for 250 in really good condition. I’ll look into those gorilla lug nuts.
Old 09-03-2019, 01:21 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That is a KILLER deal!
I LIKE TIRES!
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
