Drives: Toyota gt86 my19
radio stations problem
Good Morning
Well, I recently installed a Pioneer avh-z9200 dab on my Toyota gt86 and installed this radio cable. https://www.google.com/search?q=metr...-mobile&ie=UTF -8 # imgrc = IOqf8d0qx1akZM: I tried to search for stations and just found 1 or 2, I disassembled it again, I looked at the wiring and everything is in place, I did the test with the radio out of the hole and found more stations listening correctly to the local station, when I reinstalled the radio in its The gap remained the same as before and the local station listened badly as if you were many kilometers away from the city. Therefore, I deduce that it is not a problem with the radio but with the wiring. How do I find another compatible cable? Will it be defective? This cable is recommended by some colleagues in this forum. My GT86 is European. Thank you |
AF/FM antenna amp
There's an AM/FM antenna amplifier that's on pin 8 of the 10-pin connector. This pin needs to have 12v on it from the blue wire on Pioneer or you won't get AM/FM reception.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue 1994 Ford Probe GT 5MT - Red(some would argue pink) 1969 Mustang Fastback 4MT - Royal Maroon |
| DVD in radio problem. | Covo_86 | Electronics | Audio | NAV | Infotainment | 1 | 05-07-2014 10:33 AM |
| HD RADIO problem in los angeles | SliverBrz | Electronics | Audio | NAV | Infotainment | 10 | 09-21-2013 10:38 PM |
| Noticeably low and sharp volume with AM radio stations with stock BRZ radio | tracerit | Electronics | Audio | NAV | Infotainment | 0 | 07-24-2013 02:38 AM |
| Sorry - This Radio Sucks - Bespoke doesn't get my 5 favorite stations...Antenna..? | JohnnyNight | Electronics | Audio | NAV | Infotainment | 4 | 10-15-2012 04:26 AM |
| radio problem | FT86R | Great Lakes | 3 | 09-21-2012 03:08 PM |
