Old 08-12-2019, 05:11 AM   #1
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
2 piece rotor options for performance pkg
Gents.. I’m looking to see if there are any options out there to get two piece rotors for cars equipped with performance pkg.
I’m ideally looking to offset the weight of a bigger wheel / tire combo as well as 2 piece rotors are just so much better looking.
Thanks in advance for your suggestions
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 08-12-2019, 06:44 AM   #2
Yoniyama
Drives: BRZ 2018
Racing Brake sells a 2-piece rotor kit, for 12lb saving in (unsprung) weight, see:
https://www.racingbrake.com/RB-2pc-R...aru-p/2312.htm
Yoniyama is offline   Reply With Quote
Old 08-12-2019, 06:46 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Are these really for PP, not rather for stockers, by chance?
Old 08-12-2019, 07:17 AM   #4
Code Monkey
Drives: Subaru BRZ
Would not touch Racing Brake 2-piece rotors with a 10-foot pole, complete junk. Here's what happened after one hpde weekend in my Mazdaspeed6. Customer service asked me to send the rings back, once they received them, never heard back. Stay away.
Code Monkey is offline   Reply With Quote
Old 08-12-2019, 07:52 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
I'm not that sure if 2pc construction in general is to be blamed in this particular case. I'd rather blame these rotors being crossdrilled, thus much more susceptible to cracking under abuse (such as HPDE/track). Imho blanks or just slotted should held up much better, leaving crossdrilled just for show.
Old 08-12-2019, 09:18 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i suspect the rotors were too tight to the hats. if it was a cross drilled issue, the cracks would have been at the cross drilling, but it seems they were all at the leading edges of the rotor hat connection point.
Old 08-12-2019, 10:06 PM   #7
Grady
Grady's Avatar
Those do not appear to be for PP.
These were the only ones I could find. A little less expensive than FT86speed.
https://www.amazon.com/5654GLDXS-10-...y&sr=8-1-fkmr0
The Following User Says Thank You to Grady For This Useful Post:
Jdmuscle (08-12-2019)
Old 08-12-2019, 10:43 PM   #8
Jdmuscle
Always enjoyed DBA products.. thanks for this. I’ll more into this.
Old 08-12-2019, 10:44 PM   #9
Jdmuscle
For sure.. I won’t attribute those cracks to it being drilled. Rather improper torque specs between hat and discs.
Old 08-13-2019, 02:33 AM   #10
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We have it in our back pocket, but it's dependent on whether people appreciate a proper engineered system or something cheap, which is basically whatever is on the market right now.
CounterSpace Garage is offline   Reply With Quote
Old 08-13-2019, 03:53 AM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I don't understand your post.
CSG has 5 different brands of disc on their website. They are for sale. They are "on the market". I don't consider those brands to be "cheap" or inexpensive.
Old 08-13-2019, 07:27 AM   #12
Grady
Grady's Avatar
Yes when you go quality your customer base shrinks. Carbon ceramic option?
Old 08-13-2019, 07:31 AM   #13
Grady
Grady's Avatar
The cracks are right in the radius. All those cracks are stress cracks. That is from too much flex in that area. The bolts could be to loose but my guess is a poorly engineered rotor. That radius should be a lot less to distribute out the stress. Or they just went to light, or both.
Old 08-13-2019, 12:08 PM   #14
CounterSpace Garage
2-pc disc option for the Brembo PP? Not many options are available. The ones that are available have been tested to be pretty underwhelming (kind of like that RB 2-pc system).
Ironically, we've been asked to make a CCB option before.
A proper motorsport 2-pc disc? We can make one as long as there's a market for it, but the pad compound is really the key factor in improving overall brake performance.
BRZ with PP brakes rotor replacement options Elliotw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-16-2020 04:59 PM
Performance Pack rotor options Var Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-08-2018 03:43 PM
Lightweight REAR rotor options himbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-15-2018 04:59 PM
Exhausts options at AJW Performance! AJW Performance Engine, Exhaust, Bolt-Ons 2 06-29-2016 11:26 AM
F/S: New, Blue Anodized Aluminum 3-piece Engine Bay Cover set by Nameless Performance quackman Exterior Parts (Aero, Lighting, Etc.) 4 05-18-2015 08:28 PM
