Old 08-11-2019, 10:47 AM   #1
black.86
black.86's Avatar
Drives: 14 Scion Frs
Monogram Headlights wiring harness?
I have a set of monogram headlights that are missing the wiring harness. For the longest, I thought that part number su003-04316 was what I needed but that appears to be for the base series headlights. After taking a second look at the diagram for the monogram part number SU003-04630, it appears to be a different wiring harness. Does anyone know where I can get this part online if that is even possible? I attached an image of the diagram with the part circled. Any help is greatly appreciated
black.86 is offline   Reply With Quote
Old 08-11-2019, 11:48 AM   #2
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
You can always buy these:
https://www.diodedynamics.com/always...cion-fr-s.html
Then wire your standard 6 pin harness to that 8 pin version. I used to know the wires off of my head but it's been too many years.
You want to do the "LED mod" anyways and you also get the 8 pin connector by using those.
projek_01 is offline   Reply With Quote
Old 08-11-2019, 02:43 PM   #3
black.86
black.86's Avatar
Thanks thats a good idea.. im also missing the internal connectors though. It should look something like this pic all together minus the ballast. Found this on ebay but the guy only has one side.
Old 08-22-2019, 10:37 AM   #4
black.86
black.86's Avatar
Update
IF anyone finds themself in a similar situation, I was able to find the harnesses thanks to the Car Gods! I bought a harness and a spare monogram headlight for under 100! The spare headlight came with an additional harness plus a ballast and leveling sensor. ebay store: https://www.ebay.com/usr/autus90
headlights, monogram, monogram headlights, wiring harness
Monogram Headlights on FRS wiring HELP! Brayden_23 Cosmetic Modification (Interior/Exterior/Lighting) 29 11-03-2016 08:54 PM
WTB: BRZ or 10 series/monogram 8 pin connector + length of wiring harness NahumCC Want-To-Buy Requests 4 02-18-2016 05:08 PM
WTB: Plug and play harness for Monogram headlights FirestormFlex Want-To-Buy Requests 7 02-04-2016 02:04 PM
WTB: Plug and play harness for Monogram headlights FirestormFlex Want-To-Buy Requests 1 01-25-2016 01:44 PM
WTB: PLUG N PLAY Harness from the 10 Series/ Monogram Headlights LANI86 Want-To-Buy Requests 1 09-24-2014 11:50 PM
