Old 08-07-2019, 02:31 AM   #1
GrabTheWheel
Drives: 16' BRZ
More air in the front end please!
Can people please share what they've done to get more air flow into the front of the car? Including brake ducts and deleting the factory crash bar? Extra points if you were able to keep it looking close to stock.
GrabTheWheel is offline   Reply With Quote
Old 08-07-2019, 03:29 AM   #2
Trackspec hood vents. Delete the mustache and impact beam.
DarkPira7e (08-07-2019), why? (08-07-2019)
Old 08-07-2019, 10:55 PM   #3
GrabTheWheel
Drives: 16' BRZ
Mike, any reason to get a JDL crash bar or is it not needed? (as long as I don't crash!) Also is there any reason not to just go hoodless if I don't have the trakspec vents?
Old 08-07-2019, 11:05 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I would assume hoodless is a poor idea, the restriction creates vacuum for extraction to a degree and is a safety measure so spewing fluids don't blind you. The track spec hoodvents, modifying the stock engine shield to give vents that create more vacuum (cutting little slivers of the metal and angling it down a little to create drag) are really the best cheap and easy mods I could think of. Are you fighting poor under hood temperatures that are far beyond the norm?
Old 08-08-2019, 12:49 AM   #5
GrabTheWheel
Drives: 16' BRZ
I have the Verus hood vents for now, might upgrade to the Trackspec at some point. I have an LS3. So far just pushing the car in the canyons in 90 plus degree weather coolant is between 220-230 which I believe is normal for an LS. Oil temp is 220 off the cooler, so probably 250 in the engine. Trying to get better airflow before going to Buttonwillow at the end of the month so will probably remove the factory crash bar. I'm trying to keep the car relatively stock looking so I can still drive on the street for now. Purchased my first trailer today so I guess that was a big step towards going to a dedicated track car.
Old 08-08-2019, 01:10 AM   #6
You're overheating unless you have an unusually high set thermostat (unlikely).
Get a fresh hood and drop in trackspec vents, unless you want to need a new LS3 at that track day.
Watch your oil temps.
I personally wouldn't ever run without a bash bar at a minimum.
PM to order the JDL bash bar.
Get yourself a better radiator and shround while you're at it.
Old 08-08-2019, 01:40 AM   #7
GrabTheWheel
Drives: 16' BRZ
Thanks for the concern Mike. I have every possible Motec safety parameter in place to protect the engine. I'll also have my tuner with me at the track and I'll be sure to be cautious as well as take the necessary steps to increase cooling. Every LS guy I talk to says 220-230 is normal coolant temp for these engines.
Old 08-08-2019, 02:07 AM   #8
typical =/= normal =/= acceptable
Invidia Catless Front Pipe + Cusco Front Strut Tower Bar ThatBlueBRZ Canada Classifieds 3 08-18-2015 10:03 PM
Invidia Catless Front Pipe + Cusco Front Strut Tower Bar ThatBlueBRZ Canada Classifieds 0 08-18-2015 10:35 AM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 12:05 AM
TRD Style ABS Front Bumper Lip, CFW Trunk Spoiler, LH Lower Control Arm Front STS-V Want-To-Buy Requests 0 03-18-2014 03:42 PM
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 08:35 PM
