Old 08-01-2019, 06:54 PM   #1
Butterballz
Drives: Black FRS
Dynamically Balancing Clutch and Flywheel
I'm going to replace the clutch soon along with the flywheel and want to know what your take on dynamically balancing the clutch and flywheel together. I'm going to get the Toda Racing flywheel. I know they sell a kit together with a clutch for $1,350 and the clutch they use is just a Exedy stage one unit. However, theirs come dynamically balanced. I could buy the flywheel and Exedy clutch separately and save around $400 or more.
Necessary or one of those things that is nice to do but is not required. I could also get it balanced together if I can find a shop that does it. Thanks.
Butterballz is offline   Reply With Quote
Old 08-01-2019, 07:28 PM   #2
wparsons
wparsons's Avatar
Sounds like $400 of snake oil...
flickr
Old 08-01-2019, 07:52 PM   #3
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Every clutch kit that comes with a flywheel is dynamically balanced :/.....
Dr. BRZ is offline   Reply With Quote
Old 08-01-2019, 08:30 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like marketing lingo to me.
If you are going to pay $1k for a clutch kit, might as well go for a twin plate.
Then again, that's over kill if you are not boosted.
If you just want to same money you can always get the current flywheel re-surfaced.
Old 08-01-2019, 11:07 PM   #5
Butterballz
Drives: Black FRS
So far I'm liking the answers since I don't want to pay for snake oil.
But does it matter if the flywheel and clutch/pressure plate is dynamically balanced together?
Stock motor so no need for twin plate. Toda Racing was the lightest chromoly steel flywheel I can find. Cusco is about the same weight but costs $100 more cause Cusco tax.
Old 08-02-2019, 12:09 AM   #6
Turdinator
Señor Member
Turdinator's Avatar
I have that flywheel and an exedy clutch. I didn't balance them before installing even though I normally would. 4 of the 5 times I've had clutch and flywheels balanced in the past they needed almost no adjustment. For my previous car the flywheel bolts were known to be a little weak side so it was considered good a worthwhile thing to do. Fa20s don't seem to have that issue. I'd say its not necessary but it might be good for your piece of mind
Also when I used to get it done it would only cost me $50 so it was cheap insurance.
1974 TA22 Celica
2013 86 GT
Old 08-02-2019, 01:06 AM   #7
Butterballz
Drives: Black FRS
How do the flywheel and clutch feel in your 86? Chatter or vibrations? If you could do it again would you have balanced it?
Old 08-02-2019, 01:23 AM   #8
Turdinator
Señor Member
Turdinator's Avatar
I much prefer the feel of a light weight flywheel, there is a lot more NVH when engine braking and a little when idling wih the A/C on but other than that you probably wouldn't notice anything. I do have TRD motor and g/box mounts so if you're on stock mounts YMMV.
If I had found someone who could have done the balancing in time I would have done so before the installation but I am not worried enough to pull it out and have it done any time in the foreseeable future.
1974 TA22 Celica
2013 86 GT
Old 08-02-2019, 07:44 AM   #9
wparsons
wparsons's Avatar
The clutch and flywheel have to be separated to attach the flywheel to the engine, so even if they were perfectly balanced together, they'll shift slightly when reassembled. The clutch disc is never in the same position, so balancing it with the rest doesn't help either. The components should all be balanced on their own already.
flickr
WTB: OEM Clutch, PP, Flywheel! FRSH86 Want-To-Buy Requests 3 11-04-2015 04:43 PM
WTB OEM clutch and flywheel Opposed Want-To-Buy Requests 5 08-08-2014 01:47 AM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
