Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-01-2019, 12:42 AM | #1 |
Drives: 2017 BRZ (Sold), 2023 GR86
Brembos turning yellow..?
After ~15 track days, the logo text on my OEM 2017 PP Brembos has started to turn yellow.
I know it seems a bit vain for a track car, but is there anything I can do to prevent or reverse it? My guess is that it's a no..but hey, worth a shot! Last edited by mistople; 08-02-2019 at 01:32 AM. |
08-01-2019, 03:09 AM | #2 |
Thanks
Not that I know of, paint is for cosmetic/protection from road salt/corrosion. Track only calipers are not painted and don't have dust boots either. I seen most cars on track with discolored calipers.
08-01-2019, 06:16 AM | #3 |
Because compromise ®
Drives: Red Herring
Of course there is a solution!
Have dedicated track day calipers and separate street calipers. You will get cred at the track for having obviously tracked brakes and you will get street cred for having bright yellow "Brembo" on your calipers while cruising about town.
08-02-2019, 01:33 AM | #4 | |
08-02-2019, 02:06 AM | #5 |
Drives: 2014 GT86
Noobs. Swap cars for trackdays.
08-02-2019, 12:46 PM | #6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Free range cats and dogs in the area?
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | Tcoat (08-02-2019) |
08-02-2019, 04:56 PM | #7 |
Caused by heat. A majority of pads generate a ton of heat and it transfers into the caliper which cooks the paint. A high end brake pads has low heat transfer through the pad and reduces heat into the caliper and fluid. The energy goes towards the disc where it dissipates the heat more effectively than sinking it into all the surrounding components.
The Following User Says Thank You to CSG David For This Useful Post: | Tristor (08-03-2019) |
08-03-2019, 02:14 AM | #8 |
Drives: 2017 Subaru BRZ Limited
I don't know how to fix the discoloration (as in make it better), but I can tell you how to keep it from getting worse:
1) Buy titanium brake heat shields (Hard Brakes makes some that fit most calipers) which will help reduce heat transfer from pads to calipers 2) Run proper track pads with good construction (proper backing plate designs) will result in significantly less heat transfer into the calipers from the pads. 3) Duct your brakes to cool them resulting in lower overall temps for pads/rotors/calipers 4) Apply a high-temp ceramic coating over the brake caliper painted surface to help protect it from heat and debris (although most heat is from inside) and increase paint adhesion. |
08-03-2019, 08:52 AM | #9 |
ProCrastinationConsultant
i suggest running an air tank on the car, and connecting air hoses near each caliper to cool them down.
Similar Threads | ||||
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks | Kyogre | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 05-12-2015 04:59 PM |
WTB: Koni yellow struts and RCE yellow springs | nlowell | Brakes, Suspension, Chassis | 2 | 05-20-2014 03:10 PM |
Brembos | biggy69 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-15-2014 09:23 PM |
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! | OrbitalEllipses | Mid-Atlantic | 21 | 06-14-2013 12:10 PM |
TC turning back on after turning it off | Xdragonxb0i | Issues | Warranty | Recalls / TSB | 2 | 02-01-2013 04:19 PM |
