Drives: 2015 Scion FRS
FRS won’t go into first or reverse?
Hey guys, been trying to study this a bit but can’t find the right thread for a decent answer or someone that has experienced this.
Quick back story, recently turbo’d my FRS and with that wanted to upgrade my clutch to ACT, so it had a stronger clamp, upgraded fork and pivot w/ a lightweight flywheel. Now that that’s out of the way, the first few hundred miles weren’t anything crazy. Did the whole break in period and serviced the transmission as normal to the fill port. Now after the whole break in period, it’s struggles to sometimes go into first gear and reverse, as if it was rejecting it. And once I finally force it in all the other gears start feeling “sticky” if I play with it until I start eventually moving then everything would be normal until reaching a red light that’s when I have the problem of going back into first and start holding up traffic lol. This doesn’t happen all the time but does happen randomly. Usually not in the mornings but maybe after it’s been running for a bit. I’m sure with all the upgraded parts maybe it’s changed the geometry of everything? Will adjusting the pedal fix this? Or should I just go to a professional shop to get looked at. I’ve also been told of a “dragging clutch” but have yet to find an answer to fix it. Thanks in advance to anyone who helps! |
Hello johnowow and welcome to our happy clan -
![]() Your car's clutch being out of sorts could be due to a number of things. * low of clutch fluid - add fluid * air in the clutch lines - bleed clutch * clutch out of adjustment - adjust clutch * the shifter gate plate might have slipped over - adjust plate * other humfrz |
not playing cards
Clutch is definitely dragging. Absolutely terrible for the transmission.
Only first and second gear are affected by a poorly-adjusted top plate. Have a pro look at it. You want a few cm pedal travel at the floor before the clutch even begins to bite.
[insert cool phrase here]
Drives: BRZ Premium
How did you remove the shifter from the tranny when you did the clutch?
If you removed the shifter from the inside of the cabin that's where you fucked something up. Simple yet time consuming job.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| Tags |
| clutch, clutch adjustment, clutch break-in, clutch fork |
| Do you have VALENTI Reverse Bar + Reverse cam? *SOLVED | tiz22 | Electronics | Audio | NAV | Infotainment | 16 | 07-18-2017 12:36 PM |
| 2013 BRZ Reverse Light (Reverse & Reflector) | kberkel | Exterior Parts (Aero, Lighting, Etc.) | 0 | 08-14-2016 01:14 AM |
| Debate: Reverse in or reverse out. | paulca | Other Vehicles & General Automotive Discussions | 31 | 07-21-2014 09:56 PM |
| Reverse LED's | Cajun | Cosmetic Modification (Interior/Exterior/Lighting) | 50 | 01-22-2013 01:44 AM |
| Reverse | JayWoop | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 11-01-2012 12:13 PM |
