Old 07-24-2019, 02:04 AM   #1
d0aner
Drives: 2017 86 GTS
Nur spec side skirts install
Has anyone installed the nur spec side skirts without having to drill into the side panel?
Any tips on how to install these side skirts would be great. Thank you
d0aner is offline   Reply With Quote
Old 07-24-2019, 12:19 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
I have tried it without drilling into the side panel by using 3M only and it does not hold at all towards the rear side. This is due to the fact that there is no support on the rear side of the side skirts compared to the TRD/STI side skirts (they have mounting holes for screws to hold it up).
What I was planning to do is to get an abs plastic sheet, plastic weld it to the back of the side skirt, drill some holes thru it and hopefully get it mounted up like the TRD/STI's.
Bach415 is offline   Reply With Quote
STI BRZ Side Skirts (genuine) Install ST96030AS020-A00 Trap63 Cosmetic Modification (Interior/Exterior/Lighting) 17 06-15-2022 07:59 PM
DIY - Cheap eBay Series Blue Replica lip, side skirts, and rear apron install ShiftingLanes DIY (Do-It-Yourself) Guides 4 06-09-2018 06:13 AM
Nur Spec Front/Rear + TRD Side Skirts/Wing = WIN migueralliart Cosmetic Modification (Interior/Exterior/Lighting) 48 05-11-2018 10:07 PM
INGS N-Spec Front Bumper, Fenders, and Side Skirts HemiGoesHam Cosmetic Modification (Interior/Exterior/Lighting) 1 09-08-2016 08:25 AM
Anyone install a front lip and/or side skirts? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 78 04-06-2015 05:08 PM
