Drives: 2016 Scion Frs,03bmw z4,13' is250
OEM+ audio wiring?
Hi guys, I was wondering if anyone can help me make my own wires. I tried contacting OEM+ audio customer support a year ago through email, facebook chat, and calling them on the phone but they told me they would take on the special order since the system was outdated when they can. After trying to get an update for a month or so I finally given up so I want to try to make my own wire for the sub. I'm guessing I buy this to attach to the head unit so I don't have to splice anything. To connect to the audio wires.
https://www.amazon.com/Amplifier-Int.../dp/B00CQUL240 But I can't seem to find the connector for the unit itself. does anyone know where I can find the connectors, it looks like to have 10 pins? Attach is the picture of the amp/subwoofer connection I need. |
Drives: 2015 Scion FRS
OEM Audio
you're best bet is the run a aftermarket AMP and splice the speaker wire from the OEM Audio Plus subwoofer itself and connect it the to the aftermarket AMP.
Just make sure the AMP matches the OEM audio subwoofer spec wise. You don't actually need that harness linked above. You can use this line out converter and spliced into the factory amp in the trunk to get RCA outputs. It also has a AMP remote turn on built in. https://www.sonicelectronix.com/item...C2.html?from=3 |
Another solution is you can make your own harness with these two items:
https://www.sonicelectronix.com/item...a-71-1761.html https://www.sonicelectronix.com/item...che-TA02B.html you would need to find out which speaker is which on the OEM audio AMP and solder the connectors with the new custom harness. then un plug the factory subaru amp and plug in your custom new harness. |
| Help: Wiring Pioneer 8000NEX, OEM Audio Plus, Beatsonic Backup camera | kuro | Electronics | Audio | NAV | Infotainment | 11 | 06-13-2015 10:46 PM |
| JL audio cleansweep.......FRS head unit wiring diagram | EightSix93 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-10-2015 08:24 PM |
| Audio AMPLIFIER ASSEMBLY / Wiring - Connection | mister.bond | Electronics | Audio | NAV | Infotainment | 1 | 05-08-2014 10:47 AM |
| Audio/Wiring in SoCal | Sterz | Southern California | 2 | 02-23-2014 05:41 PM |
| SOLD! OEM Audio Plus Subwoofer + Amp + OEM Wiring | shiro | Audio/Visual, Electronics, Infotainment, NAV | 25 | 08-30-2013 07:40 AM |
