Drives: '14
Where is the DI Ecu located?
Can someone post a picture of where this is located?
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
On passenger side of engine near valve cover. Large black box with harness.
On the passenger side above the injectors
Drives: '14
![]() So this one, right? I read that the bottom bolt can cause grounding issues and I'm going to try and see if that will rule out my issues. It looks really tight...how can I even screw the bolt down there? Would I need to jack my engine up? :x |
| The Following User Says Thank You to kev0 For This Useful Post: | CSG Mike (07-17-2019) |
Drives: 2017 Toyota 86
That's it. If you can see the 3rd bottom bolt going into the block and it's tight, your ECU is grounded. What are your issues?
#6 | |
Drives: '14
Thanks! |
I got this too. Turns out the aftermarket in-tank fuel pump was not seated properly, dropping feed pressure to 38 psi. The DT flex fuel kit I have saw an out of limit low pressure and zeroed out the ethanol content signal to the ECU, making it think I had 100% gasoline instead of the e85 I actually had. It then was running leaner than it should have been, my STFTs pegged at 30%.
| Perrin 25 mm wheel spacers, 4 of them located in so cal | Lonelydriver | Brakes, Suspension, Chassis | 3 | 03-04-2019 09:14 PM |
| FS: OFT Located in SoCal | bitesthedust | Engine, Exhaust, Bolt-Ons | 4 | 11-11-2016 03:21 PM |
| Anyone located near Fullerton, CA? Help! | bcmakesiteasy | Southern California | 4 | 03-16-2014 08:58 PM |
| FS/FT Whiteout FRS AT under 5k miles located in MI | CW-FR-S | Cars for Sale/Trade | 4 | 10-04-2013 08:27 AM |
| Located Firestorm FR-S in Katy, TX | PhastekSport | Southwest | 5 | 11-20-2012 02:22 PM |
