| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Car at 16k miles. Have been doing oil changes myself, do I need to bring it in?
Hi!
I have a 2018 BRZ with 16k miles. I have been changing the oil and brake fluid myself. Do I need to bring it in for some (useless it seems) stealership check up to maintain warranty? Or could I just do the rundown myself (air filter, cabin air filter...etc) Thanks! |
ProCrastinationConsultant
As long as you keep accurate maintenance records, you shouldn't need to
Thanks
How many brake fluid changes in 16k miles? Track use? Any issues with the car?
Just keep receipts, if anything goes wrong bring the receipts and let them figure it out. Don't volunteer any info they may want to use against you. Some dealers are good some are bad.
[insert cool phrase here]
Drives: BRZ Premium
I have done every single item the maintenance schedule call out for. Minus the fuel pump.
As mentioned if you keep records aka receipts of what parts you buy it's the same as dealer service history. The only thing that might affect it, is if you trade it in or some picky buyer wants a Carfax report. But any knowledgeable person or mechanic can know the difference from a neglected and a proper serviced car.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Thanks
I have the carfax app and it lets you put in DIY service records. I also keep the receipts. But I don't know if the DIY service shows in the official report. In any case, a picky buyer will be able to tell if you maintained your car well and if your receipts are legit.
In think you're good. 20k or so is rear diff fluid change.
Sent from my SM-G975U using Tapatalk |
Drives: WRB Subaru BRZ Limited 6MT
Last time I had my car at the Subaru dealer (other than to buy the odd part from the Parts Dept) was the day I bought it new in June 2014. During my "check-out" with the salesman, I was told the car had "Subaru's award-winning AWD" and that I could count on it to keep me safe on the road. Needless-to-say, my faith in Subaru-trained employees took a significant dive that day.
Coupled with two separate incidents at two other Subaru dealers where the respective Parts Managers tried to sell me blue OEM oil filters for their EZ36D engines, arguing with me that the BRZ has an "H6" engine, I have since given up and order most everything online using the same parts fiches that apparently greatly befuddle the actual, trained employees of this company. All of this is to say, at least in the Midwestern US, you'll be better off taking care of your own car, probably even for warranty work. |
No, read your warranty documentation in the glove box.
The only reason would be if you plan to sell your car in the future, people like to see maintenance records on the Carfax reports.
#10 |
Drives: 2013 FR-S 10 series [755]
I personally don't think you need to,
Just do everything yourself as required in the owners manual. I bought the car at 19k miles, after the last free oil change, I either take it outside or do it myself. Saved a lot of $$. I oil change every 3-5k miles. (beside track days) I change brake/clutch fluid every year. I change trans/diff fluid every year. I change cabin filter/air filter every year. It's a very simple reminder and maintenance.
IG: @rearwheelclub
#11 |
Damn that's crazy...
Drives: 2015 BRZ
#12 |
Drives: '12 C63 P31, '23 GRC
Unless you track your vehicle, annual brake fluid (and esp rear diff fluid) changes are highly unnecessary.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#13 |
And so are 3,000 mile oil changes. The set schedule gives plenty of margin and shortening the interval for a street driven car is just wasteful with zero benefits.
#14 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Diff has no replacement interval. It is only inspect every 30k and replace as needed. If you only daily then fluid will look almost new at 30k miles (except on your first change, that shit will be gross). If you track with good fluid you shouldn't need to replace fluid more then once a year basically (unless your pedal gets soft, then bleed and maybe think about new fluid). Otherwise it's every 30k miles. |
| 67k miles, will bring car in for valve spring recall, what else to fix down there? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 12-19-2018 12:59 PM |
| Sometimes dealerships bring it on themselves | torqdork | BRZ First-Gen (2012+) — General Topics | 10 | 04-15-2015 01:21 PM |
| Where to bring used oil? | vincent201089 | Southern California | 9 | 04-12-2013 02:44 PM |
| What to bring to a track day... | PMok | Tracking / Autocross / HPDE / Drifting | 19 | 12-30-2012 05:55 PM |
| Don't bring your car to Mr. Tint! | ngabdala | New England | 3 | 08-29-2012 01:29 PM |
