Old 07-09-2019, 06:29 PM   #1
jc7993
Drives: Looking to buy
Valenti Sequential Tail Light Issue
Was installing the Valenti Sequential Tail Light and connected the power cable to test it out and saw that the brake light became the turn signal and vice versa. Any idea if this is a known issue? One thing that I think might cause the issue is the Smartap CF18 Flash Relay that I installed a month ago. Besides that, I haven't made any other modifications.
jc7993 is offline   Reply With Quote
Old 07-09-2019, 08:22 PM   #2
Raiderboy66
Drives: 2015 Subaru BRZ
I got mine last week and the running light was the turn signal and the turn signal was the running light. I found a video that showed the proper sequence for the wiring harness and so I switched the yellow and blue wires and then they were fine.
Raiderboy66 is offline   Reply With Quote
Old 07-10-2019, 04:35 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes. The US has different wiring to the rest of the world. The lights aren't made in the USA, therefore the pins have to be swapped. Usually the vendors over there swap them (or have them swapped in the factory) but if you've imported from elsewhere they'll not be done.
Tons of info on this website about re-pinning the lights.... or YouTube
.: Stealth 86 :.
Kodename 47 DJ:
Sequential Valenti Tail Light Video+photos- Now DOT approved continuecrushing Cosmetic Modification (Interior/Exterior/Lighting) 11 09-25-2019 02:59 PM
WTB: Driver side Valenti Red Tail light (Sequential or non) bokehmon Want-To-Buy Requests 0 01-12-2019 10:08 PM
Valenti Tail Light Non-Sequential Clear Lens Gundam Exterior Parts (Aero, Lighting, Etc.) 5 09-25-2018 12:34 PM
FS: Valenti Sequential tail lights, Reverse/brake light: SOLD!!! turbotention Exterior Parts (Aero, Lighting, Etc.) 6 12-09-2017 08:47 PM
Sequential Valenti LED Tail Lights Smoked Lens Red Light Bar Yoda Exterior Parts (Aero, Lighting, Etc.) 5 07-03-2017 02:09 PM
