Old 07-08-2019, 03:44 PM   #1
sman
Drives: Scinon Fr-s
Diagnostics tools for DIY
I have a 2013 frs with roughly 60k on the clock. I'm starting to venture in to the world of preventative maintenance. I have purchased the service manual and reading through it stumbled on the mention of an SSM3 to use for diagnostics. I understand its a tool dealers use to diagnose and trouble shoot problems.
The questions are as follows.
  • Is it possible to acquire this tool.
  • How much does it cost, I imagine its expensive.
  • What have people used as alternative.
  • Has any one used the OBD2 how far will this go to replace the SSM3
  • What other workarounds exist.
As one example the procedure for testing the ignition timing (among others), requires this tool.
sman is offline   Reply With Quote
Old 07-08-2019, 04:41 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Just get an oft. It tells you all that info.
Dr. BRZ is offline   Reply With Quote
Old 07-08-2019, 05:09 PM   #3
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Don't get an oft, wth. $400-500 for oft. You can get an obd2 dongle from Amazon for $5-50 (mine was 20), then buy obd fusion or torque on your phone. It's has more info than you'll need and can read and diagnose stuff. Get an oft if you need a basic ots tune and the diag stuff, but not for diag stuff alone.
I use my obd2 to do logs, read codes, clear codes, run guages for my boosted brz (oils Temps and tune info (afr, etc)).
In 4 years I've never needed more than the obd2 to solve the few issues I've had with the car.
You can do more than the above with obd2 iirc, but that's all I've used it for.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 07-08-2019, 05:11 PM   #4
Strife26
Strife26's Avatar
This is how I roll. It's awesome.
Old 07-08-2019, 05:27 PM   #5
steve99
Techstream factory software will work on all brz 86 frs , clone version like $40 on ebay with vci cable
Android torque app and elm 327 blutooth adapter about $15 all up
Obd scan tool about $40 on ebay comething like a Launch Creader will scan clear obd codes and also show reatime ecu data like fuel trims afr and more
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
Tools huynh_FRanciS Other Vehicles & General Automotive Discussions 7 03-18-2016 05:36 AM
System Diagnostics Say R-Cam and USB NG ChrisJ Electronics | Audio | NAV | Infotainment 1 02-18-2015 08:28 PM
Tools and their uses CoupedUpSubie DIY (Do-It-Yourself) Guides 17 12-20-2014 02:50 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
