Drives: 2013 Subaru BRZ
CVT issue?
I have a little above 82k miles on my transmission and was wondering if this is a normal sound. It sounds like its coming from under the vehicle, and it resonates back towards the cabin as you drive by cars / walls.
https://streamable.com/ojcki |
#2 | |
Drives: 2019 BMW ///M4
| The Following 2 Users Say Thank You to N1rve For This Useful Post: | pinoy_dorifto (07-03-2019), why? (07-16-2019) |
When was the last transmission fluid change?
humfrz |
Drives: 2017 Subaru BRZ PP WRB
A recording from the engine bay may be more useful, but what you posted doesn’t sound like an auto transmission sound. If the fluid has never been changed, then it won’t hurt to have it changed anyway and it would eliminate that as the possible source of the noise.
| The Following User Says Thank You to NCtoBRZ For This Useful Post: | humfrz (07-03-2019) |
#7 | |
#8 | |
That sound may be coming from a bearing (idler, alternator, compressor). Can you isolate it with a stethoscope type rig? humfrz |
#9 | |
CVT issue?
Ill try and see if I can. I’ll pickup a stethoscope and update. If it makes a difference, the noise picks up as I step on the pedal. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to xkenx1995 For This Useful Post: | humfrz (07-03-2019) |
#10 | |
I got the stethoscope and I got some noise out of these 2 pulleys. I just pulled this image from google as it is too dark for me to take a decent picture. Any good after market recommendations I can look into? A pulley kit has been on my list for a while so I might as well pull the trigger on this. ![]() Sent from my iPhone using Tapatalk Last edited by xkenx1995; 07-03-2019 at 01:47 AM. Reason: fixed formatting |
#11 | |
You may consider taking the belt off and turning each pulley to see if it feels lose or spins rough. If the bearing in one of the pulleys is bad, just changing the "wheel" part of the pulley isn't going to help. humfrz |
#12 | |
I’ll remove the belt and find out Sent from my iPhone using Tapatalk |
#13 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
If you do suspect pulleys, after you take the belt off, start the engine and listen for the noise again. If you still hear it, don't bother spinning pulleys cause that's not it. If the noise does go away with belt removed then yep, start spinnin.
Work Hard. Play Hard.
2016 Oceanic |
#14 | |
Thanks for the tip. I’ll keep that in mind. Sent from my iPhone using Tapatalk |
| Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 05:15 AM |
| Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 09:49 PM |
| HELP! CEL + TC issue!!! | JC0830 | Issues | Warranty | Recalls / TSB | 45 | 01-28-2017 05:33 PM |
| BRZ Nav MP3 issue | TheRipler | Electronics | Audio | NAV | Infotainment | 5 | 09-06-2013 03:21 PM |
| Cel issue | Z06tofrs | Issues | Warranty | Recalls / TSB | 2 | 08-27-2012 11:13 AM |
