Old 07-01-2019, 04:57 PM   #1
gman6974
Drives: 2018 BRZ
Spark knock/pre ignition noise. 18k miles
I'm in NC so it's getting hot here. I've noticed the past couple weeks I'm getting what sounds like spark knock when going into 4th, 5th and 6th gear. I can snap the throttle in these gears and get the sound.
Do these cars run lean from the factory? I'm thinking a simple tune could alleviate the issue.
Anyone else come across this?
gman6974 is offline   Reply With Quote
Old 07-01-2019, 05:32 PM   #2
ermax
ermax's Avatar
Are you getting this when doing quick shifts and quick jabs? I have a 2013 and it did this really bad until I updated my Transient Ignition Retard tables to match the 2017+ tables. The throttle response isn't as good on the 2017 tables though. I switched to E85 and rolled back to the 2013 TIR tables and no longer have the knock and also got my throttle response back.
I see you have a 2018 so I wouldn't expect this to happen to you. Maybe your haven't a different issue.
The Following User Says Thank You to ermax For This Useful Post:
DarkSunrise (07-02-2019)
Old 07-02-2019, 11:35 AM   #3
wparsons
wparsons's Avatar
What gas are you running? I wouldn't be surprised if it's on 91, if you can get 93/94 give a tank a try to see if it stops it.
flickr
Old 07-02-2019, 12:11 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I almost always get knock at around 2600-3200 if it is under load. This is a pretty high compression engine. I've pulled so much timing at one point to get rid of it I gave up. I run the car hard at the track all day and IAM never moves from 1 so
Old 07-02-2019, 01:36 PM   #5
gman6974
Drives: 2018 BRZ
Yes I get this noise during quick shifts and jabs in these gears. Sounds like the same issue you were having. Also running 93.
Old 07-02-2019, 04:38 PM   #6
ermax
ermax's Avatar
Well running the 2017 TIR almost completely fixed it for me but still on a quick shift I would hear it randomly. E85 has completely solved it. I literally never see signs of detonation in my logs anymore.
Old 07-02-2019, 05:26 PM   #7
gman6974
Drives: 2018 BRZ
May go the e85 route then. I hate hearing it.
Old 07-03-2019, 03:07 PM   #8
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
My car does this as well on an older OFT stage 2 tune (1.8X IIRC). Is this ultimately harmful to the car or can I just chalk this up to being another noise it makes. Thoughts on whether or not I should upgrade to a newer tune?
nastynate88 is offline   Reply With Quote
Old 07-03-2019, 03:33 PM   #9
gman6974
Drives: 2018 BRZ
Sure it causes some stress wear since those cylinders are firing off at slightly the wrong time.
FS: OEM Spark Plugs (@577 Miles) zeal86 Engine, Exhaust, Bolt-Ons 3 07-31-2018 06:06 PM
4 OEM spark plugs and 1 OEM ignition coil Kronos Engine, Exhaust, Bolt-Ons 12 07-29-2016 11:08 AM
Ignition Timing and Knock Shadeslayer AFRICA 3 05-06-2015 06:44 AM
(Spark?) Knock on cold start idle nickw14 Software Tuning 0 04-07-2015 01:41 PM
Transient ignition and knock count brn12345 Software Tuning 19 06-11-2014 12:46 AM
