Old 07-01-2019, 01:35 PM   #1
Scjacob827
Drives: 13' BRZ
NRG Hub hard to turn?
So the other day I installed my NRG Hub with a DND Wheel bolted directly to the hub (so no quick release) and its fairly difficult to turn the wheel both left and right. Is this common with aftermarket wheels or is something wrong on my end?
Any input is appreciated!
Scjacob827 is offline   Reply With Quote
Old 07-01-2019, 02:47 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Something is wrong, shouldn't have any change to steering effort.
maslin is offline   Reply With Quote
Old 07-01-2019, 03:02 PM   #3
Scjacob827
Drives: 13' BRZ
Hmmm Ill take it off when I get home and take a look. I think it could be possible that I tightened the hub too much. Maybe causing friction against something, although it didn't look like it
Old 07-01-2019, 03:31 PM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Is your new steering wheel smaller than the OEM?
BigTuna is offline   Reply With Quote
Old 07-01-2019, 04:01 PM   #5
Scjacob827
Drives: 13' BRZ
Diameter is 350mm
Depth is 75mm
Old 07-01-2019, 04:03 PM   #6
BigTuna
BigTuna's Avatar
Idk what the OEM diameter is, but a smaller wheel can make steering feel heavier. However, if it's actually "Difficult" to steer, then there is likely a different problem.
Old 07-01-2019, 04:10 PM   #7
Scjacob827
Drives: 13' BRZ
Its not like I am fighting the car to steer but its definitely feels a lot "heavier". I think it could be possible that the wires that I tucked beneath the hub could be tangled in some fashion causing resistance.
Old 07-02-2019, 09:40 AM   #8
Scjacob827
Drives: 13' BRZ
Fixed it!
Took the hub off and moved around the wires I had tucked beneath it. Not only did this correct the "heavy steering", it also fixed the steering angle sensor issues I was having which was throwing an ABS and Traction light.
The Following User Says Thank You to Scjacob827 For This Useful Post:
BigTuna (07-02-2019)
Old 10-16-2019, 01:58 PM   #9
scotto79
Drives: 2016 Ablaze FRS
Originally Posted by Scjacob827 View Post
Fixed it!
Got any pics of how close it is compared to stock?
This is the same setup I wanted to do without the quick release, but can only find NRG short hubs.
scotto79 is offline   Reply With Quote
Old 10-17-2019, 10:41 PM   #10
Scjacob827
Drives: 13' BRZ
Unfortunately I never took pictures of the stock setup
Old 10-18-2019, 11:44 AM   #11
scotto79
so what is the distance like to the turn signal switch now?
Right side turn signal does not turn on Feargt86 Issues | Warranty | Recalls / TSB 4 10-02-2018 01:10 PM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
