Drives: 2018 Subaru BRZ
Ft86 catted header OFT tune?
I have an FT86 catted header on the way that I found used for a pretty good deal. The only thing is that the previous owner says the cat is no longer in because his super charger blew it out. Once I install the header which OFT tune would benefit me the most but also run safely the stage 2 catted tune or the stage 2 no cat tune?
I did reach out to open flash this was the response: I can't say if you have a CAT or not. You need to check. Use whichever map corresponds to your physical hardware -- BUT understand that the mapping was developed with ACTUAL hardware described ... not a "variant" or "modified" version of the described hardware. .... A catted header, with a broken catalyst is not the same as a non-catted header physically speaking. There may be no ideal map for you because of the unique header you have. Sent from my iPhone using Tapatalk |
Drives: Subaru BRZ 2017 PP
What exactly is your question?
It seems like you got the information you needed to hear. |
Check to see the condition of your cat. If it's in good condition, run the catted header tune. If it's blocked or falling apart, gut it out and run the catless header tune.
2022 BRZ Build 2013 FR-S Build |
#4 | |
The question was what Openflash tune I should use due to the header I have coming in that was originally catted but had the cat gutted out. I still wasn’t sure with the response I got from Openflash. Sent from my iPhone using Tapatalk |
| WTB FT86 Catted Header | alphasaur | Want-To-Buy Requests | 0 | 11-12-2018 02:05 PM |
| WTB: FT86 Speedfactory Catted UEL Header | hachigoku | Want-To-Buy Requests | 0 | 07-16-2018 08:56 AM |
| jdl catted header OTS tune ok? | deuncos | Software Tuning | 43 | 06-13-2018 02:34 PM |
| FS: FT86 SF Catted UEL Header SoCal | stoked_on_spool | Engine, Exhaust, Bolt-Ons | 8 | 04-05-2016 10:29 PM |
