Old 06-18-2019, 05:29 PM   #1
S0crates
Drives: 2017 BRZ Limited PP
Enkei PF01 17x8 +35 on BRZ PP
I am looking at buying a set of Enkei PF01 17x8 +35 (Black) wheels for my 2017 Subaru BRZ PP. I plan to run either 235/45/17 or 245/40/17 GT Radial SX2 tires. My suspension is stock and I don't plan to run coilovers. Maybe just some camber bolts and possibly some RCE yellows in the future.
Should I expect any fitment issues without spacers? From my research, these should clear everything just fine, with a little bit of poke in the front which can be fixed with the camber bolts or lowering. From what I can tell, it should clear suspension and the guards just fine. Will I have issues clearing the Brembo brakes?
Here are some articles for reference. No one has specificaly states the 17x8 +35 will clear PP BRZ, but based on these, my guess is it will clear no problem.
17x7.5 +45 with 225/45/17 will clear PP brakes.
17x8 +35 with 245/40/17 will clear stock brakes/suspension
17x8 +35 will clear the AP racing sprint brake kit
http://www.ft86club.com/forums/showt...highlight=PF01
S0crates is offline   Reply With Quote
The Following User Says Thank You to S0crates For This Useful Post:
atomicalex (07-30-2019)
Old 07-30-2019, 01:42 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by atomicalex View Post
Plenty of clearance, at least as much as the OEM wheels from the spokes (actually probably about 3mm more to the face. The barrel is similar to OEM, maybe a hair more clearance.
I have the 17x8 et35.
Crappy pic...
Nother one...
Here
timurrrr is offline   Reply With Quote
Old 07-30-2019, 03:46 PM   #3
atomicalex
Drives: 2018 BRZ Limited Perf Pack
My wheel guy called Enkei directly and they specifically recommended the +35 fitment. Because I was concerned, too.
They look great and fit with no issues, can still clear my hand past the suspension front and rear.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Wheel Directory: Enkei PF01 17x8.0 +45 NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-30-2019 09:39 AM
Enkei PF01 - Silver (17x8 +45) - Baltimore DrButtDrugs Wheels and Tires 9 01-26-2018 02:39 PM
My New Wheels - Enkei PF01 17x8 +35 86_Freak Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 11:10 PM
Enkei PF01 17x8 +35, anyone have? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-10-2014 01:46 AM
Should I? Enkei PF01 5x100 17x8 +35 Gregory Gawaran Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-07-2013 08:55 PM
