Old 06-17-2019, 05:25 PM   #1
RedPandas
Drives: 2018 BRZ
What does it mean when advance multiplier increases?
So my standard advance multiplier on ecutek is set at .7, however yesterday on the highway it went to .74. I know that dropping on adv multiplier is pulling timing so does increasing it by .04 advance timing? If so, why would this be the case? (I'm a turbo)
RedPandas is offline   Reply With Quote
Old 06-17-2019, 05:56 PM   #2
tomm.brz
Drives: brz 2017 hksv2
when advance multiplier is lower than 1, then the ecu constantly tries to advance (rise) ignition timings to increase performance
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
RedPandas (06-17-2019), Spuds (06-17-2019)
Old 06-17-2019, 05:57 PM   #3
secho
secho's Avatar
Drives: GT86, forged and supercharged
Final timing = base timing + (ignition advance * IAM) + compensations. So it means that rising IAM => adding spark => it is ok, engine not knocking (in such areas).
Odesláno z mého SM-G973F pomocí Tapatalk
secho is offline   Reply With Quote
The Following 2 Users Say Thank You to secho For This Useful Post:
Old 06-17-2019, 06:15 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes it advances timing as it increases. If it increases, it means your ecu is not detecting knock. If it decreases it means your ecu is detecting knock. When less than 1, the ecu will continually try to increase ignition advance, then listen for knock at that level. If the amount of knock crosses a threshold, it decreases advance and checks again. This lets it hover right on the edge of maximum advance (and therefore maximum performance) for current conditions.
The Following User Says Thank You to Spuds For This Useful Post:
Old 06-17-2019, 06:21 PM   #5
steve99
Increasing advance multiplier is usually a good thing, it means little or no knock detected.
Its a little unusuall that your tuner has set advance multiplier intial at 0.7 and not 1 like most tuners will on turbo or sc cars.
Hopefuly they tuned car with advance multiplier at 1 for little or no knock then set it back to 0.7 for safety.
If they tuned it at 0.7 advance multiplier , then the ecu will keep adding timing till it knocks, this isnt rearly that good on a turbo or sc car. I saw this a while back when a tuner unfamiliar with subaru tuned a car.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Old 06-17-2019, 06:21 PM   #6
RedPandas
Drives: 2018 BRZ
So could the reason for the timing to advance be temperatures dropping outside?
Old 06-17-2019, 06:26 PM   #7
RedPandas
Drives: 2018 BRZ
How will I know they tuned at 1.0 or not? Or is that a question for my tuner?
Old 06-17-2019, 08:29 PM   #8
steve99
Look at the IAM befoe you turn car off, if its above 0.7, say 0.75 and then you turn car off. Then turn car on and start, if iam went back to 0.7 then iam initial is set to 0.7 not 1.
If iam is beliw 0.7 then its not posiible to tell.
Ecu will set iam initial value of iam if iam was higher than iam initial when engine switched off, if it lower than iam jnitial it remembers lower value
How to set Advance Multiplier...when you first start your car? chazmuska Software Tuning 6 07-25-2018 07:30 AM
Question about Advance Multiplier Jasonb Software Tuning 20 03-06-2018 06:37 PM
Why does my Advance Multiplier keep dropping? jeebus Software Tuning 103 10-17-2016 05:29 PM
Advance Multiplier at 1 in log? orangespark Software Tuning 5 10-21-2015 03:32 AM
advance multiplier = 0 why???? agent47 Software Tuning 11 01-28-2015 11:11 PM
