Old 06-10-2019, 05:21 PM   #1
deku
Drives: 2017 subaru brz red, 93 FD RX7
wheel set up
Hey guys, i just wanted to make sure im doing a proper wheel set up. so my wheels will be 18x8 et48 and i will be using 5mm spacers for the front, 10mm for the rears. with using spacers im thinking of upgrading the wheel studs to the ARP 2.535 inch studs and using open ended lug nuts. would the 1.95 studs be long enough with the oem nuts? any opinions or experience doing this kind of set up?
deku is offline   Reply With Quote
Old 06-10-2019, 05:28 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you contemplated using bolt-on spacers? May be less trouble. And easily reversible!
The Following User Says Thank You to DarkPira7e For This Useful Post:
Leonardo (06-11-2019)
Old 06-10-2019, 05:36 PM   #3
deku
im not sure if they have them for 5mm/10mm spacers. i figured since the ARP's are a bit more durable they would be a better option
Old 06-10-2019, 07:23 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Why da funk would you buy spacers?
Get the right offset.
Play around using the tire/wheel calculator
The Following 3 Users Say Thank You to Mr.ac For This Useful Post:
kch (06-11-2019), maslin (06-10-2019), Shizuka (06-10-2019)
Old 06-11-2019, 02:54 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You will need more than 5mm and 10mm spacers to make your wheels flush.
I would use 20mm bolt-on spacers in the front and 25mm bolt-on spacers for the rear (if your wheels have "pockets" on the back). If not, I'd use 25mm bolt on spacers all around. The rears will be flush, your fronts will need a set of camber bolts installed.
I LIKE TIRES!
Old 06-11-2019, 04:00 PM   #6
wparsons
wparsons's Avatar
If you're buying new wheels, just buy the right offset so you don't need the spacers at all.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
kch (06-11-2019)
NASA SCCA FRS Full Racecar Wheel to Wheel Competition ST5 ST Class BRZ 86 hirollaz Cars for Sale/Trade 1 10-22-2018 09:13 PM
East Bay NorCal: OEM Wheels, free wheel lock set and wheel totes akacinna Wheels and Tires 2 05-07-2018 12:53 AM
FS: Sparco steering wheel setup/ b2autodesigns wheel adapters sebastiansim NY / NJ / CT / PA 1 11-12-2015 07:57 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! YURparts Wheels and Tires 3 12-16-2013 09:07 PM
