Old 06-09-2019, 10:49 AM   #1
lorip713
FRS trunk not opening
I have another post floating around here somewhere. I was away for awhile and now back dealing with the same issue. My trunk won’t open. I pulled the back seat down. The valet mode button is off. You can hear the trunk pop when you push the trunk button on the key fob but nothing happens. The emergency pull doesn’t work. It won’t open with the key. Any suggestions before I go back to the dealer. It’s a 2013. Thanks.
lorip713 is offline   Reply With Quote
Old 06-09-2019, 11:01 AM   #2
p1l0t
p1l0t's Avatar
I think if the key and the emergency pull won't open it you need to go to the dealer.
Old 06-09-2019, 11:37 AM   #3
Dake
Dake's Avatar
Yeah - the emergency pull not working is weird. That's a direct, mechanical connection to the release mechanism. It's odd that you can hear it unlatch but it still doesn't.
Dake is offline   Reply With Quote
Old 06-09-2019, 12:18 PM   #4
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Stupid questions. Once you hear it unlock, have you tried pulling/pushing the lid open? Have you tried lubing the latch? It may not be opening enough to release.
PetrolioBenzina is offline   Reply With Quote
Old 06-09-2019, 01:45 PM   #5
humfrz
OK.
Are you sure the latching mechanism is being released?
Insure that opener lever inside the car has returned to its down position?
Are you pushing the valet switch the "open" way?
Insure that you are pulling the emergency rip cord the proper way?
OK, now that you are sure the latch is releasing, I suggest the following:
* have someone push and hold the trunk button the FOB, while you are aggressively pushing down and pulling up on the trunk lid.
* if that don't work have someone hold the button down, while you crawl into the trunk space and pound "up" in the trunk lid from the inside.
Iffen none of that works, either break out a crowbar or take it into a shop.
Let us know when you get it open -
humfrz
Old 06-09-2019, 01:51 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would suggest putting some pressure on the trunk lid while hitting the trunk button on the remote. sometimes it can be latched too tightly.
Old 06-10-2019, 04:53 PM   #7
lorip713
I’m not even sure how to do that. I don’t see anything to lube instead the trunk.
Just a black box covering where the latch might be.
Old 06-10-2019, 04:54 PM   #8
lorip713
Tried this. Didn’t work.
Old 06-10-2019, 05:50 PM   #9
jordan7831
Drives: 2016 Halo FRS
Are you able to get into the trunk from the cabin and using a screwdriver to move the lock over to one side to release the mechanism?
Originally Posted by Mr.ac View Post
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
Old 06-10-2019, 11:45 PM   #10
humfrz
Well, lorip713, did you get your trunk open??
humfrz
Old 06-11-2019, 01:07 PM   #11
p1l0t
p1l0t's Avatar
humfrz
Would be nice, it's getting hot in here.
Old 06-11-2019, 01:41 PM   #12
humfrz
Hang on, Bubba is going to send his son out to open it up -
humfrz
Old 06-11-2019, 10:28 PM   #13
soundman98
soundman98's Avatar
humfrz
wow. JUST SAY NO to tool-on-tool violence!
Trunk opening after "spirited" uturn. JDM FRS Issues | Warranty | Recalls / TSB 30 08-22-2013 10:08 PM
Trunk not opening grgonium Issues | Warranty | Recalls / TSB 4 02-06-2013 03:47 PM
trunk opening it self Im_SPEED Issues | Warranty | Recalls / TSB 12 09-10-2012 10:49 PM
Trunk not opening FRomar-S Scion FR-S / Toyota 86 GT86 General Forum 11 08-16-2012 05:23 PM
Opening in GTA group buy Sport-Tech CANADA 6 05-23-2012 11:17 PM
