Drives: 2016 scion frs
A/c problem / future issue
Today after taking the fiancé to lunch we got back in the FR-S and to my dismay the a/c didnt respond (No blower fans running in the cabin) So I pulled the fuse which was still good and reinstalled. Checked the a/c and it ran normally
. Anyone know if this could be a bigger issue on its way?
I wouldn't worry about it, unless it did it again.
You might consider buying a new fuse to have on hand, in case it acts up again. humfrz |
Thanks, will get an extra fuse.
Only thing that just happened was I had it on 4 and it was blowing only lightly but when I selected 2 and put it back on 4 it was normal. So weird. |
Benz Tech
Drives: 2017 BRZ Premium
Sounds like a blower motor going out. They'll get stuck at a certain point, then take off again.
not playing cards
What level lightly? Like 1, 3, or less than 1?
Was blowing lightly at 3 then I turned it down and off then back on all the way to 4 and acted normal since then. Bought an extra fuse just really hoping the blower motor lasts
#7 | |
Benz Tech
Maybe it will run forever and never stick, maybe it won’t. Blower motor and regulator are cheap and easy to replace. |
| Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 05:15 AM |
| Strange issue - looking for suggestions - Possible DI or Coil pack problem | sfruski | Engine, Exhaust, Transmission | 6 | 10-02-2018 02:07 PM |
| Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 09:49 PM |
| Can a Transmission Problem be diagnosed with this issue I'm having? | Veloist | Issues | Warranty | Recalls / TSB | 3 | 10-03-2015 10:03 PM |
| Oil leak problem, possible seal issue from repair? | tintumz22 | Issues | Warranty | Recalls / TSB | 12 | 04-02-2015 01:56 PM |
