Old 06-05-2019, 04:06 PM   #1
SmoothIsSlow
Has anyone been able to A/B a PP versus tS?
Hi all,
I have a '18 PP manual that I began tracking. I saw that my friends who started before me all eventually began adding chassis stiffening parts as well as big GT style wings. I was wondering if I could find a cheap, slightly used tS in the future, if it would be a good idea to swap out my ‘18PP with a ’18 tS (the extra red interior bling is tugging the heart strings of the dark, ricer part of my soul.)
Has any track rats here been able to A/B the PP against the tS (or the new TRD 86)? Do the big carbon wing and splitter help stability on track at all?
Thanks!
SmoothIsSlow is offline   Reply With Quote
Old 06-05-2019, 04:17 PM   #2
15limited
15limited's Avatar
Its oem aero, man. You're just comparing trim packages at this point, same chassis. Honestly I dont think either package is worth any more than a stock 86 or brz
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
SmoothIsSlow (06-05-2019)
Old 06-05-2019, 04:47 PM   #3
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
the only thing that matters is the 4.30 diff and the stock suspensions (maybe brembos)
but utlimately ^ is right, its just a wing and lip and some sti braces, that frankly can be had from the parts catalouge. I built a 2018 brz tS outta my 2015 frs and i wish i hgotten the brz in the first place. it was hard and expensive and timely
Clutch Dog is offline   Reply With Quote
Old 06-05-2019, 06:55 PM   #4
SmoothIsSlow
Right! If I decided I wanted the tS enough, I would just trade in the '18 PP for a tS.
The Following User Says Thank You to SmoothIsSlow For This Useful Post:
Clutch Dog (06-06-2019)
Old 06-05-2019, 07:29 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Honestly it would be cheaper / easier in all likelihood to add the parts (or similar aftermarket) to your pp brz. The ts on the used market will be tough to find and likely command a premium.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
SmoothIsSlow (06-06-2019), Tristor (06-05-2019)
Old 06-06-2019, 12:50 PM   #6
RayRay88
Drives: 2017 86 860 Special Edition
BRZ with 17+ dampers/springs and 4.3 FD, with a cattless UEL/OFT tune, and old Azenis.
The TS was a solid second or two faster out of the box. I'd be curious if he could close that gap with better tires, but he speaks a lot about the stability and confidence gained from the rear wing.
RayRay88 is offline   Reply With Quote
The Following 3 Users Say Thank You to RayRay88 For This Useful Post:
new2subaru (06-06-2019), nikitopo (06-08-2019), SmoothIsSlow (06-06-2019)
Old 06-06-2019, 12:56 PM   #7
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I'd be extremely surprised if the tS was measurably faster if both came out of the showroom with the same tires.
mistople is offline   Reply With Quote
The Following 5 Users Say Thank You to mistople For This Useful Post:
15limited (06-06-2019), 86MLR (06-06-2019), NoHaveMSG (06-06-2019), SmoothIsSlow (06-06-2019), wparsons (06-14-2019)
Old 06-06-2019, 06:35 PM   #8
RayRay88
Around a fast track, I wouldn't doubt a second or two gained with a decent wing. It would still be a good comparison.
Over all unless you're hell bent on getting the Ts looks with a warranty, you could easily get your sport pack to run as fast or faster for much cheaper.
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 06-06-2019, 07:08 PM   #9
Clutch Dog
This is a fact. Ill have a build profile up where i mechanically changed my 15 frs to a 18 TS including all the bracing and aero bits.
sadly it wont be a good comparison vs a PP, but should someday someone put out a video request of a stock PP vs a modded base vs a tS im sure i would rise to the call.
really though my car isnt a good basis for comparison anymore since it is prepped for STX (ish) which means stuff was swapped out over a stock car. (like running V720 225's vs the stock tS' 215s?)
Old 06-06-2019, 08:13 PM   #10
mistople
mistople's Avatar
Maybe. I don't see a second or two in that wing. But I'm in for the results if anybody wants to prove me wrong!
Old 06-07-2019, 04:19 PM   #11
Shadotracker
Drives: 2018 Subaru BRZ TS
TS owner here. I was able to get my car out on COTA recently and get some very "rough" times. I was in blue group (I put myself there since I was rusty and haven't been on a track in years) and was only allowed to pass on the straights. The only mods I have done to my car is a Nameless muffler delete and a Whiteline 22mm FSB, everything else is stock.
The "fastest" time I got was a 2:58, but I was stuck behind a bunch of trains in the turns.
I know a high 2:4x - low 2:5x is easily possible when I can get a clean run in.
As for the wing, the rear does feel more planted in the high speed turns and stable on the long straights.
Shadotracker is offline   Reply With Quote
The Following User Says Thank You to Shadotracker For This Useful Post:
Old 06-07-2019, 04:25 PM   #12
Clutch Dog
You also have extra bracing which would lend itself to a different feel.
where you on stock tires?
Old 06-07-2019, 04:42 PM   #13
Shadotracker
Yup, same tires from the factory when I bought it. I've done 6 autocross events, 1 track day and daily drive on the same tires.
Clutch Dog (06-07-2019)
Old 06-07-2019, 04:45 PM   #14
I've A/B with the same tires on both cars.
The tS is minimally more stable, but virtually no performance increase, due to the sheer amount of WOT time spent in both cars.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
Clutch Dog (06-07-2019), nikitopo (06-08-2019), NoHaveMSG (06-07-2019), strat61caster (06-07-2019), subielife (06-11-2019), wparsons (06-14-2019)
86 versus VW Golf GTI djmm FR-S / BRZ vs.... 88 05-07-2016 07:16 PM
Michelin PSS versus AS/3 boomslang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-22-2014 11:40 PM
FR-S AT Versus SLK280 Wayne FR-S / BRZ vs.... 2 06-11-2014 02:42 PM
E85 versus 100 octane Deep Six Software Tuning 14 11-12-2013 07:02 PM
OEM HID versus TRS HID Anomie Cosmetic Modification (Interior/Exterior/Lighting) 23 10-24-2013 04:03 PM
