Drives: brz
300g/s at 140kpa 6800rpm
C
Drives: UK GT86
The problem with this is that by changing the MAF scale you can get completely different readings, or where the MAF is located can have a big impact. Unless it's on an identical setup running the same tune, the MAF output is pretty much irrelevant.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | tomm.brz (05-28-2019) |
Drives: brz 2017 hksv2
there are many variables and tolerances in each sensors and actuators (injectors for example) so that every single car is different and as kodename said you cannot compare this
you would need two identical cars tuned the same way (di/pi, lambda scaling, other sensors scaling, corrections ecc) and even then you see differences
even lambda position for different headers matters |
Don t really getting what you are talking about. you scale the maf on your specific car to make the afr reflect the target, and SD is the same. if you change pipe diameter the air sample will have different characteristics than before so you change it to make the voltage measure adeguate grams of air, that then provide adeguate fuel to have afr similar to target
Identical cars with same exact mods and configs, will always bave differences, mostly because of the sensors and injectors that have tolerances can be similar, but never the exact same |
of course is an extimated value of airflow, but there are so many variables and ways that tuners can tune this car that you can't take it as an exactly measurement of how much air is entering
Drives: brz
I just figured if subaru said it flowed let's say 30g/s at 1 v, that 30gs would be flowing thru the maf, then we put in a bigger housing and scaled it correctly we should be able to know when 30gs is flowing by our new calibration. At least pretty close, well at least closer than + -50% accuracy.
You really can't estabilish mathematically how the scaling woud be if you change X things, or, better, you maybe could but then you just rely heavily on the fuel trims to adjust things
and stock logic doesn t even fix trims really good during open loop the maf just samples a tiny portion of all the air that is entering, and you never know what REALLY happen inside the intake/charge tube, you can t know how much turbulence there is Hell, even a differenr panel filter induces different flow For good maf scaling forget the math and do good logs and fix things from them |
#9 | |
Drives: UK GT86
It will give you a ballpark idea if many of the parameters haven't been played with too much and on the same setup.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | tomm.brz (05-29-2019) |
#10 |
Air flow vs pressure and velocity is not simple
